Originally Posted by
Actually with the winding resistances you quote, the cartridge will be loaded with 56.5Ohm, so not a short circuit. However the voltage divider formed by the 100Ohm loading of the phonostage with the 12.47KOhm of the secondary winding will mean the 0.2mV output of the cartridge appears as 0.045mV at the phonostage input.
If you use a good quality digital multimeter having a high impedance, so draws very little current, then you might probably get away with using it to check winding resistance, but in general it is wise to be cautious. If you use something like an AVO then you could well easily magnetise the core. Most transformers used as MC cartridge SUTs explicitly state that no DC can be tolerated on the primary windings (Haufe, Lundahl or Cinemags for example).
How is it now behaving with the phonostage set to 47KOhm?
