Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: DIY BMU build
    Bigman80 Guest
    Default DIY BMU build
    Here it is. All built but need to swap the 10a MCB for 6a MCBs
    It has removed the intermittent powerline adapter noise. Only problem is, I have a buzzing sound now.
    Any suggestions?
    Looking good Oliver,
    But the MCBOs need to be ganged, so that if one trips out due to a fault condition, both live (115V) conductors are disconnected. Ideally you should use a 2-pole ganged RCBO.
    Bigman80 Guest
    They are connected by a metal pin, Barry. Of one trips, they both trip. Tried and tested.
    Ah - I couldn't see that from the photo. It would be better still if a two-pole residual current circuit breaker was used, to provide protection against asymmetrical current leakage.
    I'm Gary.
    The buzzing probably means you have DC on your mains.
    Get a DC blocker in there Oliver, either in the chassis if you have room or an external box between the mains feed on the wall and BMU.
    Fitted one to my Airlink unit recently, buzzing is gone.
    THe BMU, whats your perception of sound quality changes?
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    Bigman80 Guest
    There is a DC blocker in there, it does reduce mechanical hum.
    Well, it seems the BMU is not having the desired effect. I am getting more hum now than previously. I have stripped everything out and put in place a multi plug which I built. Very simple, just wired with standard flex and switchless sockets and stared plugging things in one after the other.
    I have some hum on the Phonostage which I hadn't realised but the Rothwell SUT is adding to that. The IC cables I use aren't shielded so that needs addressing. But it's 90% quieter without the BMU. Looks like it'll be for sale.
    Barry,
    I agree but it was just put together with bits I had to see if it would be beneficial and it's not, in my house anyway.
    So the BMU is out, DIY multiplication is in.
    I'm Gary.
    Mines is hardwired and my mains is shit...may be a factor.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    Bigman80 Guest
    Right, I take it back
    I've taken the SUT out and the phonostage and put the Vivant in with direct MC connection.
    Volume on full and the mains sounded horrific but NO hum. Dropped the BMU back in volume on full and voila, almost silent.
    So diagnosis is - Wizard phonostage needs a bit of help to dispel the hum and the SUT needs some position help.
    Sound with the BMU in is clean. Almost added a bit of depth and dimension.
    Way to go ....
    We'll try some fixes with the Wizard to see where it is lacking, could be that a resistive link to the chassis may be beneficial.
    Bigman80 Guest
    Right, Rothwell SUT back in with the Vivant and......... No hum, hiss or nasty sounds. SO.....it's the bloody Wizard phonostage.
