Just get an oppo. Good price and does everything you need
Ignore ... misread a prev post
Firstly well done for chosing to stick with CD replay over streaming, as convenient as streaming is you could get a far inferior sound if you get that side of things wrong. Yes you could simply use a Chromecast Audio, but it sounds like you value the quality of sound, and at your level plus experience you won't get that with a GCA. Chosing a great CD player avoids a possible complicated digital infrastructure to support a very good sound from a streaming service such as Tidal for example. I would only chose the GCA to 'supplement' a good CD player unless you know how to put together a streaming infrastructure that approaches or even exceeds CD replay. You can avoid BubbleUPnP, DLNA, Squeezelite, Roon and all those bits and pieces that, in the end, can make a fab front end - but just look at all the terminology you need to get your head around.
Anyway - I have a good CD player - vintage - Technics SL-P990 in great condition - £200 if you are interested - cheap enough and very high quality.
As I suggested earlier, go for a streaming solution. Last year I bought another Raspberry Pi3 and an Allo DigiOne board. It performs fantastically with my ripped FLAC files and impressively on high bit-rate internet radio. The technology almost completely eliminates jitter, and I am hearing detail and nuances on old tracks that I never heard before.
Geoff
I have a CDP which is on a par with my record player; well, as near as damned, according to sundry hifi visitors. Different, certainly, as are most CDs, but with a quality disc, as spacious and naturally revealing a my vinyl front end. It's called a Lector (4 box for my part), but I'm sure there are other valved CDPs out there which would slot in as your second record player, as it were.
Technics SP10 mk2
Miyajima Shilabe cart
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Audio Note ANe-SPX speakers
Just a thought, my mate tried a valve pre and it totally fried his dac beyond repair, could be a fault in the amp that caused it rather than the other way round.
I'm Slav.
I agree and it's messing with my head. Before the Opus the balance on the truth was set at 4 minutes past. Since the Opus was put in it is now at 20 past. Hence my question about whether the Opus could have damaged the input. The seller is suggesting that I have somehow shorted the output on one channel of the Opus - I don't see how.
It rained all night here and i spent all night dealing with a flood at home.
It seems I have ac choice.
Send the arc for service.
Keep and send the Opus for service.
Or try to return the Opus and send the arc for a service.
I really don't know what to do. If there is no way the Opus could damage the input on the arc then the drop has to be coincidental. And it's only right I keep the Opus. If there is any possibility the Opus could damage the input then better to try a clean sheet and not risk it happening again.
Advice welcome!
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
I'm Slav.
It's very unlikely cd player would make any damage to an amplifier ,
It's very long thread can you remind me what's the balance like when you plug adjustable output to the amplifier?
Another solution is to take Opus and your amp to ARC service centre , guys there certainly would be able to check outputs of the player and tell you if is faulty or not
if you've paid with PayPal you have 90 days so there is no point to make rushed decisions , someone would need to swallow 100euros postage cost
