Page 4 of 32 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 311
Thread: Electrostatic/Planar Speakers
  1. #31
    I'm Phil.
    highly recommend martin logan , there are electromotions around and theos etc
    Eric Bibb
  2. #32
    Quote Originally Posted by hifinutt View Post
    Thanks Phil I will take a look at those as well..
    Bev
  3. #33
    I'm Dennis.
    OK if you can tolerate the visual imposition.
  4. #34
    Dennis the size is not a problem to me as I only have myself to please... absolutely no WAF here
    Bev
  5. #35
    I've posted the same question on the Naim forum and someone says that the SN2 driving a pair of 63's was absolutely no problem so I am hoping that it will be enough for the Maggies as well.. we will see
    My 'bargain' Maggies will be with me in about a week or so once I've collected them, I will report back as soon as I have a 'handle' on them
    Bev
  6. #36
    Not sure how to reply to that!
  7. #37
    Bev
  8. #38
    Thanks for the comments Martin, are the 63's really bad then ? I did read some negative's about 63's but again I guess if they are cheap enough then maybe worth a go just to get a feel of the sound and to see if they would work in my room before moving on to something better in the electrostatic/planar field
    No but the newer models are better built, better all round. 63s are old now and will need a lot of work unless you buy some that have had it all done already. Same with 57.
    But I see you have gone for Maggies so academic now.
  9. #39
    Hope the Naim works with the Maggies but they are not comparable to electrostatics in terms of amplifier requirements. I have used 300w monoblocks with my 1.7s and they reminded me of AudreyII in the Little Shop of Horrors! They still wanted more juice!
    Geoff
  10. #40
    I'm Dennis.
    My concern was not so much with WAF, but my own situation to which yours may be similar.
    You may remember the picture of my Betas with the front window behind in the centre from the "Show us your speakers" thread.
    A few years ago I sold a pair of CLS 2s for a friend, and they sounded good but virtually blocked out the front window, and I could not live with that. They also dipped to 0.5 ohms.
    Mind you the Betas are not diminishingly small, but they are not wide, and I've given up seeking a Dom.
