Some of us prefer to be Naimless!
Bev
Certainly my riskiest hifi purchase ever, I didn't even hear them, it wasn't 'that kind of deal' if you know what I mean and the seller didn't have anything to hook them up to anyway
I was just amazed when I wired them up and sound came out to be honest
Bev
I don't know your room dimensions, but before you find a final position for them, try bringing them right out into the room. I would say around 3/8th the length of the room. You don't need them too far from the side walls, as being dipoles they do not radiate much energy laterally, though they do benefit from a few degrees of toe-in.
I think you will be amazed at the scale of the image they can create and how such large panels can disappear sonically.
Geoff
Colin has offered to build me a set of stands that will place the Maggies at 90 degrees which I think will be better than the 'lean' of standard stands, bless him
At the moment I have no stands at all and I've just plonked them on the stone bases I used with the LV's and leaned them onto the back wall, with suitable rear padding... as I said the placement is completely rubbish at the moment so I know they have a lot more to give
The Maggies sound, even with the current rubbish placement, is just lovely. They have absolutely no listener fatigue and sound rich and musical to me
Bev
I'm Sandro.
Quite agree !!!!
my room is 16Ft X 15 FT being GF less they are on the widest wall much further apart than when I was using the Polk
I still have the loan pair and the new ones should arrive by the end of the week.
Bearing in mind that I have the Paradise whit stock value RIAA (bit lively hi cut) I found that a 0.47 R replacing the bridges improves things a bit
I have also had a chance to try the Supremus Cable and for the first time I can say the difference that made was quite evident straight away
I have a 1 meter set of this on order It is a 6 CSA cable and I wonder if the same CSA cable made up whit multiple runs of trirated 0.75 would do the same trick
Well I have the reference so I will experiment same time in the future.
I am new to Maggies and I do realise that they are different from ported floor standers, punch in the tummy and air pressure volumes are not there, but IMO staging and details make the compromise scale tip in the Magies favour.
So what should I expect from the brand new pair out of the Box ? I been told that they take a while to run in
I'm new to Maggies as well
What loan pair do you have Sandro ?
What amp are you using?
Bev
I am on my second pair of Maggies and I did not find they took time to run in. My current pair are 1.7s and I have not found them deficient in terms of "shifting air" but as I have said (ad nauseam) they take a lot of driving to come alive. It took some time to get the amplification right. Never bothered with resistors as I find the balance fine for me. The biggest weakness for me with Maggies is getting them stable and firmly mounted. I built my own stands which raise them about 25cm off the ground and provide a much more stable base.
Geoff
