Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 68
Thread: M55e Jico SAS
  1. #51
    I'm jamie.
    just use a 5mm socket and tighten with your hand,not a ratchet. thats all i do.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
  2. #52
    I'm jamie.
    Great stuff, Jim. Turntables and cartridges is an area I do have considerable experience in, so it's good to see some of the recommendations I've given to people working out, indeed as was also evidenced recently with Jamie's 103SA
    yes im very happy with your advice mate,im enjoying the guided journey,each step is an improvement.
    My System
    John Wood KT88 Amp.
  3. #53
    usually hold nut with a finger and tighten top with an allen key. prefer them on a driver for single handed use. i dont tighten them much;just enough to stop cart moving. removable headshells are a must for me
    As you can see from my photo the nuts are on top and the bolt has an allen key head on the bottom. Nice and easy to hold allen key steady on bottom and hopefully nip up nuts with mini spanner.
    I have often wondered which way the bolts for cartridges should be used, nuts on top or nuts on bottom, but searching round the net it matters not. Depends on cartridge design essentially.
    I much prefer pre threaded modern cartridges.
  5. #55
    Yup I'm as per usual doing it the other way to everyone. A trait I guess. Lol
    Haha
  7. #57
    I have often used different bolts in the past, usually to add more or less mass to the cartridge. I have now read a post on vinyl engine which suggests that changing the headshell/cartridge bolts which have a different mass actually changes the resonant frequency of the cartridge which I presume is a little like changing the material of the cartridge body.
    So in effect you can change the sound of the cartridge by using different bolts! Interesting?
  8. #58
    You could change the sound of your cart by changing the bolts I suppose but I think the changes would be so small as not be to be heard. Personally I'd be more worried about using magnetic bolts near the cartridge.
    PRE
  9. #59
    Apparently the M55e is almost carbon copy of the Shure V15 but built under normal quality control and with a different body but its electrical performance was nearly identical. The V15 had a reputation for thunderous bass and big soundstage which is what I have noticed with the M55e. It has some balls in this department and really does give me quite a lot more bottom end. I would say it is a tad fuller with the standard stylus than the Jico SAS although the SAS is better controlled and articulated.
  10. #60
    Geoff, can you point me in the right direction for some nylon washers. Cartridge moved again and I think the steel washers aren't helping.
