I've just picked up a new dac with a wal wart power supply and fancy seeing what effect a better psu will have, has anyone got anything? It needs the standard common 12v plug with centre positive.
Best to specify what current you need, plus the common power plug comes with 2.1 and 2.5mm centre pins, just to confuse the issue.
I'm Dennis.
I have one of these that I no longer use;
https://m.ebay.co.uk/itm/Finished-65...YAAOSwTapV6S-S
It’s the 12v version
£60 inc postage
Mac Mini M1 + Roon + HQ Player+Audirvana+J River + 2TB Evo ssd for music.
Sotm 200 Ultra, ISO Regen, Etheregen, HDPlex, Kecces P3, LDA, Supercharger linear PSU's
Lampizator L4G5 balanced + DSD512 Dac.
EAR V20, Woo Audio WA22
Kef Reference LS3/5a speakers, Van den Hul M.C. CS122 Hybrid speaker cable, Missing Link, Neotech, Belden, mains & interconnects, Audeze LCD-4, Senn HD800s, ZMF Atticus, Smyth Realiser A16, IsoL8 Minisub2
Get one of these https://www.maplin.co.uk/p/maplin-41...r-supply-xm20w on offer ATM for £15
They are internally adjustable and I have one set to 12v and another for 15v.
Cheers Lee
"Best to specify what current you need, plus the common power plug comes with 2.1 and 2.5mm centre pins, just to confuse the issue.
I thought you could use an overspecified supply safely but not an under as the current drawn would just be what's required, is that correct? But yes I need to say the minimum current. The one it came with is 3a but I've tried a 2.1a one with good results. I'm not sure about the pin, it's the same as a supply I bought without having to add any adaptors, which I assumed meant it's the default on a generic supply.
I have the previous version which is adjustable. I would be very surprised if this wasn't. Yes screwdriver and MM is all you need.
If you are worried I'll sell you mine for £15 + P&P, which is adjusted to 12v.
Cheers Lee
Was it marketed at 13.8 volts or whatever? Was the potentiometer external on yours?
This looks similar, 13.8v but walmart, those well known electronics experts, say it's suitable for 12v devices.
https://www.walmart.com/ip/Pyramid-2...upply/22866715
