I've finally sat down and programmed a Logitech Harmony 600 (I had to nab my wife's laptop as the Logitech software doesn't work on my Linux laptop) I had doing nothing (we'd tried it to control out TV set up, but my wife didn't like it - too complicated).
The Harmony 600 works fine with the Bryston BDA-1. The inputs are displayed in the small display at the top of the remote, so it's very easy to select the input I want.
And ... the remote also works with my Schiit Sage Pre-amp, Marantz NA7004 (which I now just use as a DAB radio), and Rega Apollo CD player. So I've managed to put away a small collection of remotes.
The 600 isn't available new any more, but the 650 is about £80.
I'm a great fan of the Logitech 350, which is very simple to use, and wife friendly. We've used one to control our TV/PVR/DVD/Amp in our lounge for many years. However, I think the 600 is better for my Hi-Fi setup as the screen makes it a little more flexible.
Rob.
Powered by crossed fingers and clenched buttocks
ive been considering getting one for a while. just felt it might be too much for me these days
Oh! and by "programming" I mean: opening the MyHarmony software, connecting the remote, adding a "New device", and entering "Bryston" and then "BDA-1". Job done. Sync the remote and all the inputs were there to select in the remote display.
Rob.
Grant,
My brother's a big fan of the cleverer Harmony Remotes, but I want something simpler. I cannot over state how much I like the Harmony 350. It's everything I want in a TV remote, and they are only £40. The Logitech software, while not prefect, is by far and away the best software I've seen for programming a remote control. Logitech have a huge database of compatible devices, so it is usually just a case of entering the manufacturer and model name. If you only have four devices to control, the 350 is great. If you've got more devices, or the inputs are a little more complex, then I think you need to move up the range.
This is the simpler 350:
Rob.
birthday is coming up
Thinking out the box...
Got an android phone?
A few of them have IR Blasters built in, and theres a lot of good universal remote apps.
Nice big screen to work with too.
If your phones not got one, what about an older 2nd hand phone that does?
Could work out cheaper.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
I hope we never get to the stage where a remote costs £400 and no one says how much??!!!!
Clearaudio Emotion with Clearaudio Performer cart
Copland CDA 266
Copland CSA 28
Squeezebox Touch
Impulse Lali
Van Damme I/Cs and cables
