Results 1 to 10 of 12
Thread: Speaker Jumpers - Reco's please
    I'm Robert.
    Default Speaker Jumpers - Reco's please
    Any recommendations for some top quality speaker jumpers for not daft money ? Seen silver ones but big bucks ......
    My System:
    Amplification - Sansui AU-919 Complete overhaul, upgraded, re-capped. Caps upgraded from 4 x 15,000 uf to 4 x 20,000 uf-inside original oval caps. All glue and 'black flags' removed
    Turntable - Modified Technics SL1210 MK5G
    Mike New precision bearing, bearing base plate, ETP Platter
    Micro Seiki MA-202 tonearm, rewired, hybrid ceramic bearings
    Ortofon Cadenza Black moving coil cartridge
    Yannis Tome 423.5 Silver-Litz tonearm cable with KLEI Pure Silver Harmony plugs
    Ebony armboard
    Audio Technica MS-8 Magnesium headshell, Ortofon pure silver headshell leads
    Isonoe Isolation Feet
    Paul Hynes SR7EHD PSU (plus regulator modules), DCSXL pure-silver DC lead with Jaegar low impedance connector
    CDP - Pioneer PD-91
    Speakers - Mission 752 Freedom
    QED Silver Spiral speaker cable, Airlock plugs - bare wire amp end.
    Mains - Ultra Pure silver plated un-switched socket, Missing link EPS 500 silver plated plugs with Hi-Fi Tuning gold plated silver ceramic 13 amp fuses
    Go bare wire at both ends and use your existing cable is my "reco".
    Quote Originally Posted by agk View Post
    +1
    If you have any bits of speaker cable lying around, you can easily make jumpers from that. Which ever cable it is, it will sound better than the brass strips usually supplied by the speaker companies.
    I'm Richard.
    Hi Robbie,
    I have a pair of Chord Carnival Silver Plus doing nothing as my new speakers are single wire only. Spade to banana. 20. PM me if interested.
    Richard
    Analogue: Linn Axis/Akito/Hercules/Eroica LX/Puresound T10/P10
    Digital: Cyrus CDi/PSR into Border Patrol SE DAC
    Amplification: Puresound L10 pre into Modwright KW150SE
    Speakers: Boenicke W8
    Interconnects: Oriton Orange Symphony
    Speaker Cabling: Townshend Isolda
    Mains: Various MCRU kits/Russ Andrews Power Cords/X Block
    I'm Robert.
    Quote Originally Posted by Dickchy View Post
    Hi Robbie,
    Richard
    Meant to say thanks for the kind offer Richard but decided to go with some Chord signature jumpers which I'm yet to try.
    My System:
    Ebony armboard
    CDP - Pioneer PD-91
    I'm Richard.
    No problem Robbie. Good luck with the new gear.
    I'm Robert.
    The Chord signature jumpers have arrows on https://www.google.co.uk/search?q=ch...UXTPU7lO-MqfM:
    Do the directional arrows matter with jumpers ? somehow I doubt it - I'm looking to go spade end for HF upper speaker posts and banana plugs into LF lower speaker posts......
    My System:
    Ebony armboard
    CDP - Pioneer PD-91
    I agree with the bare wire approach. My Reference 3a De Capos do not have a crossover but the two drivers have their own connectors. I use them with bare cable by strippng off 3" of insulator and then adding a bit of shrink wrap so that the cable is only exposed where it passes through the binding posts. A little bit of solder at the tips of the cable stop it from unravelling. Sorted. Much better than the heavy duty copper bars that are fitted as jumpers.
    Geoff
    I've got some Chord Odyssey going spare, which I can make up into bare ended jumpers. Just donate a couple of Quid to Cancer Research and I'll send them to you.
