Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 64
Thread: What gives a system slam and dynamics?
  1. #21
    I'm Neil.
    Critical damping of the speakers is an essential component of tight 'slam' and 'dynamics'. Without it, the sound can be one-note, plodding, boomy etc.
    Also, whilst you might gain a bit more 'transparency' with a passive preamp, you lose slam & dynamics compared to an active.
    The speaker / amp interface is important i.e. can the amp dump enough current into the speakers during musical peaks.
    Some analogue sources may lack slam & dynamics too, much less of an issue with digital.
  2. #22
    That's a bit of a sweeping statement. What evidence is there for loss of slam and dynamics with a good passive preamp?
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
  3. #23
    montesquieu Guest
    Purely subjective I would assume but that is also my experience.
  4. #24
    None. They are completely un-related.
  5. #25
    I'm Neil.
    Yes, my subjective experiences (too). Have used some very fine passives and actives. For my amps and system I prefer actives. Slam and dynamics are two particularly interesting traits to compare between the two IMHO.
  6. #26
    again we come down to one man's slam and dynamics over anothers'. guessing different folk have different definitions
    I guess. I have hooked my passive up to a Krell and some Akai speakers with 15 inch bass drivers and the slam almost had me over the back of the chair. With some recordings it feels like you are being pummelled, it is actually too much.
  8. #28
    I'm Shaun.
    Back in the late nineties I used a pair of Castle Harlech speakers with a 300B PP power amp. Around 2000 I changed to a studio power amp with around 300 Watts per channel and some hefty current delivery. The difference in bass grip and control was absolutely mind blowing. To me, that kind of bass grip and control is all about the amplifier.
  9. #29
    I'm Neil.
    Default What gives a system slam and dynamics?
    For me slam is also about phase / time domain accuracy. If the bass bits hit you with a time delay and out of phase the whole tune isn’t going to “slam” together. This is mainly a speaker issue... you want all the bits to hit your ears at the same time.
  10. #30
    montesquieu Guest
    For me slam is also about phase accuracy. If the bass bits hit you with a time delay and out of phase the whole tune isn’t going to “slam” together. This is mainly a speaker issue...
    Speaker + Amp (because it's always the two together). Big Tannoys have large area and perfect phase (due to the dual concentric alignment of drivers) I don't call it slam though it's more about bodily impact of the music. The word slam to me conjures up the wrong thing - inappropriate pyrotechnics.
