Results 11 to 20 of 23
Thread: Biasing pots and where/how to measure
    Anyone owning amps containing hum pots should give them occasional attention. Once pots are set then they are often not touched for many years. Indeed mine were a bit scratchy in the speakers when being adjusted.
    Treatment with Deoxit did the trick. A huge benefit is that the residual hum in the speakers can now be adjusted to almost zero.
    SW1X USB I Signature
    SW1X DAC II Special
    Passive Volume Control
    Ron Welbourne DRD 45 monoblocks improved by SW1X
    SW1X Open Baffle Speakers containing vintage alnico drivers - Grundig tweeters, Saba Greencone midrange and Altec VOTT 416 bass.
    I'm martin.
    Finally got round to measuring plate voltage and the bias - it seems to have been waaaaaay off!
    I just hope that the resistor is indeed 10ohms! The amp is AB.
    Plate voltage 470V
    I re-biased to 31.6mv
    The values were:
    1 was 41mv
    2 was 45mv
    3 was 44mv
    4 was 35mv
    Quote Originally Posted by martinswimmer View Post
    Plate voltage 470V
    31.6mV across a 10 ohm resistor means there is 3.16mA flowing through it. I have no idea what the circuit is but 3mA quiescent current sounds a bit lower that what is typical.
    This bit makes no sense to me:
    The values were:
    1 plate voltage: was 41mv
    2 plate voltage: was 45mv
    3 was 44mv
    4 was 35mv
    41mV plate voltage??
    I'm martin.
    No, I took off the plate voltage because it was 470V and forgot to delete "plate voltage" bit.
    CORRECTED!
    I used a calculator for biasing - so picked 3.16mA - would you say that's too low?
    Quote Originally Posted by CornishPasty View Post
    I used to have one of Lim's original AVC EL34 amps and the output sections looks pretty much like the OP's Diva. Bias was stated as 39mA but I used to set mine at 36mA. If I can find my original circuit diagram I may be able to confirm the anode voltage.
    Yes, round about 30mA sounds like a typical value. 3mA? Sounds very low.
    I suspect the OP is measuring something else entirely, though I could be wrong. Without a circuit diagram, or some brave soul with a lot of spare time to trace out the circuit, there's too much guesswork here.
    I'm martin.
    I divided the value by 10 - so 316mv
    I'm not sure what that means.
    I'm not sure what that means either.
    What resistor are you measuring the voltage across and what is it doing? Are those voltages measured with respect to 0V or are you simply measuring across the resistor?
    I'm martin.
    Common ground.
    31.6 / 10 = 316
    I'm martin.
    31.6 / 10 = 316
    316 / 10 = 31.6
    In any case, sounds much better now.
