Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Re-Capping
    Default Re-Capping
    Hi all
    When would you consider re-capping a power amp? Does it start sounding different, less dynamics perhaps? Maybe just after a certain length of time? Just wondering
    Chris
    Most modern Amps of decent quality should last 20 years if not over used or abused before trouble occurs but that's just an estimate and every one will be different. Only way to be sure is to test the caps
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/B&O SP1/EMOTIVA XPS1/12V BATTERY - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP\WE TUBED - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER24, SPOTIFY - SMSL M6 MINIDAC - RPI/AUDIOPHONICS/5V BATTERY - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
    Do things just sound different?
    I'm Shane.
    If it ain't broke, don't fix it!
    S.
    Quote Originally Posted by Lerxst View Post
    often yes.. lose a bit of drive and speed etc.. bass can drop, and its possible for hum to appear. Will often go for 30 years but can be a lot earlier. Different makes of Cap fail worse than others.
    If in doubt, take it to someone for a service.
    Grant ....
    Ok, cheers,
    I just wanted to know what the symptoms are really. Not going to interfere until then.
    Thanks
    Loud bang, blinding flash and billowing smoke!
    I guess that's possible , but more likely you'll just hear anomalies in the sound. Electrolytic caps can show their age visually by leaking or swelling.
    I'm Paul.
    Generally if a powersupply cap goes duff it either explodes, swell or it starts to leak DC current and eventually can cause a fuse to blow. There can be more subtle issues but you need a scope to see what may be going on.
    ~Paul~
    I'm james.
    PSU caps can cause hum as they age. Coupling caps can fail and shunt large DC voltages into the circuit with sometimes catastrophic results to the amp and/or speakers. Any mid price Eastern amp from the mid nineties to the mid noughties could have faked 'branded' caps installed during manufacture and need a good look at. Before and after this time you should be pretty safe.
    I'm I'mteachingmarcotheartofpishanto.
    What amp is it and how old ?
    Music , fills the gaps between silence !
    TAT Sale post Leader " Marcos Mentor "
    Also a pishanto specialist confirmed by Head Daftee
    Real name " Allen " or "Zoomer Nut”, “Numpty Napper”.
    ±± KEEP IT REEL
