Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: BVA imports?
    Quote Originally Posted by snowman_al View Post
    Like others I wonder if some that we see are now the genuine article. Bigger profit in labelling something Mullard...
    Counterfeit valves are quite common; especially those of well-regarded and sought after manufacturers such as Siemens and Telefunken.
    Bigman80 Guest
    Don't forget that Mullard was only a part of the Philips group.
    If a 'Mullard' valve was in short supply or not a type made in the UK it had to have 'Foreign' or later 'Imported' on it to comply with BVA rules.
    Philips coded (99%) of their valves with an etch code system so you can identify the valve type, the manufacture plant and date it was made.
    Have a look round the bases to see if they have a Philips manufacture etched code.
    If it is a PC88 there should be a 'JE' type code followed by the symbol of the plant it was made in and then the date code.
    Not always easy to see the code though.
    Lots more here: https://frank.pocnet.net/other/Phili...CodeListAB.pdf
    Great information!!! I'll have a look
    I'm gone.
    I was peeved once when a "Telefunken" valve I bought off ebay turned out not to have the diamond on its base.
    Actually I didn't return it as it sounded very good!
    Bigman80 Guest
