Results 1 to 8 of 8
Thread: Caiman SEG power on or off?
    I'm Bill.
    Default Caiman SEG power on or off?
    Are you leaving your Segs powered up 24/7 or turning off when not in use?
    I do like to leave mine on, but have a concern I might be shortening its life.
    Chord Mojo / Sennheiser HD600
    I turn mine off but then it's running off a battery.....
    I'm Jo.
    Default >>>
    When not in use my SEG is off.
    I'm tony.
    Mine is left on...only had it a couple of weeks so letting it bed in.
    I'm Gareth.
    I leave mine permanently on. Only switch it off if I’m swapping cables.
    Turn it off! It's a complete myth you need to leave your gear on 24/7. It will take some time to warm up and then stay that way
    PRE
    I agree.
    Leaving equipment on just ages components and the fire risk from unattended electronics may void house insurance.
    I'm Bill.
    I wasn't thinking of SQ, more the longevity of the electrical components within the SEG.
    I suspect it's 'horses for courses' some components last longer when turned off, whilst others are more likely to fail by continually being turned on and off.
