Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Review of "The Big" cable or Olivers new prototype cable
    Default Review of "The Big" cable or Olivers new prototype cable
    I got these just before Xmas and have had a good listen to them. The cable is very fast, detailed and open. I compared these protoypes to the Mark Grant HD1000 cable and found that they had considerable more detail than the Mark Grant cable. I noted that cymbals had greater shimmer and I could see into the music more with Oliver's cables. Heavier music seemed to have more of an impending doom feeling, bass was fuller, faster and just over all better defined than the Mark Grant offering. They are an instant improvement over the Mark Grant. The construction of the cable is very good, quite sturdy, especially for it's prototype status. They do have a certain "sound" and can sound a little strident with high treble but this is only a minor gripe and one which will not spoil your experience whilst using them. I did manage to guess some of the cables components due to their sonic nature, my lips are sealed! Overall, I think the cable should do well at the proposed price point. I certainly enjoyed my time with them.
    Many thanks Oliver.
    PRE
    Bigman80 Guest
    Thanks for taking the time to cast your ear over the cables, Andrew.
    I think if there is a "Bandwidth" available in cables, these certainly deliver more than any I've tried. I agree that on certain material the HF can be a bit, well, strident, as you say BUT it is never out of control or breaking up. In fact, I can't think of a time it's been unpleasant to listen to. The revealing nature of the cable doesn't mask anything. If it's on the recording, it comes through and that hasn't always been the case with the cables I've previously owned.
    The price point..... at an estimate they would cost about £75 for 1m pair to buy and the construction is a bit better refined now. All things learned from the guys and girls who have had them on loan and fedback their thoughts.
    I use these cables daily and I love them. But I would, wouldn't I
    I'm Deleted.
    Silver plated copper? That’s supposed to give the character Andrew describes. Personally I’m not so convinced; although I think it can be true I don’t think it’s a given in the way some seem to think (I’m not suggesting Andrew thinks this).
    Account Deleted
    Bigman80 Guest
    It is silver plated.
    I'm Deleted.
    But not copper...... ? Not the silver plated steel stuff used for microwave transmission?
    Account Deleted
    Bigman80 Guest
    I didn't know they made silver plated steel ?
    Yes - RG316, RG714 amongst others, use a central conductor that is silver-plated copper-coated steel.
    Bigman80 Guest
    Silver plated on to copper plated steel? Why on earth would anyone do that? Why not just go and plate directly to copper?
    Yes - RG316 and RG174, amongst other coaxial cables, use copper-plated steel for the centre conductor.
    It's an option, some versions simply use copper-coated steel. I'm not sure if the copper coating is plated or if it is a done by a rolling cold-weld technique.
