Results 1 to 10 of 10
Thread: Turntable wall mount
    I'm Simon.
    Default Turntable wall mount
    With a toddler in the house i'm looking for a good turntable wall mount btacket. Luckily it's a solid wall so there should be no issues fixing it.
    I'm considering either a hifi racks wall shelf:
    Or a quadraspire:
    Does anyone have any experience of either of these shelf or recommend something different?
    Sent from my SM-G930F using Tapatalk
    Source: Thorens TD124 Rega RB300, Sumiko bluepoint No2., Cambridge Audio D500 Special Edition CDP, Squeeze box Touch, PC with Trends Audio USB Audio DAC UD-10 Amplification: Croft Micro 25 basic pre, Leak Stereo 20, Trends Audio Class T TA-10, Fisher X100-A Speakers:Impulse H6 Interconnects: Handmade silver and TNT audio CAT5 speaker cables
    I'd recommend you make a shelf yourself. Similar to the Hi-Fi Racks should be pretty straightforward and not cost a lot to do. Alternatively, brackets from Homebase, B&Q etc with a slab of wood or granite might look more elegant.
    That's exactly what I've been using for years. I use a pair of these: http://www.wickes.co.uk/Wickes-Heavy...330mm/p/530744
    With an offcut slab of thick kitchen worktop rubber mounted on top. Works a treat and very strong!
    I'm Allen.
    I have a Target wall shelf im not using , Black steel welded frame , Black wooden shelf with adjustable spikes that the shelf sits on for leveling , £50 plus postage or you can collect
    If you want something better looking than DIY
    I'm paul.
    Quote Originally Posted by simon e View Post
    Or a quadraspire:
    both look more form than function. I would go with the wickes brackets and make a nice shelf. I would also drill the holes in the brackets and use 6mm rawl bolts.
    I'm guy.
    No relationship with "Al" !
    but nice offer - very effective support and reasonable price.
    I'm Simon.
    Thanks for the replies everybody, to be honest not what I was expecting, but will investigate the diy options.
    I'm assuming decent strong brackets and something fairly dense for the shelf.
    Al, thanks for your offer but given the size and weight it would probably quite expensive to post to Ireland.
    I'm Nat.
    Custom design do a very nice TT wall shelf £169.99.
    I'm bernard.
    Hi Simon
    Get in touch with Richard at
    Customspeakerstands.co.uk
    He makes all types of Hifi furniture at very very reasonable prices
    He’s a great guy to deal with very helpful and friendly.
    Bernie
    I'm Kevin.
    I have the HiFi racks shelf, and it is a very solid support for my turntable.
    I picked it up second hand, so it was good value for money. The only snag now is that I want the matching equipment rack.
    Kevin
