Hi,
I'm hoping there might be some Mac experts who might be able to help a technophobe in need of assistance!
Essentially I have no sound from my digital source. I run a late 2012 Mac Mini i7 with 16 GB RAM with Audirvana (latest version) feeding a Heed Obelisk Da with the 24/192 USB card. Anyway, out of nowhere I've got no sound output. The only thing that has changed is that I upgraded the Aurdirvana software, so logic would dictate that that is the prime suspect; but iTunes doesn't output sound via the DAC either, and both Audirvana and iTunes work fine through the internal Mac speakers. I've changed the USB cable without success and I've independently tested the DAC on another source (via USB) and it worked fine.
When it comes to Mac's I don't really have a clue past the basic stuff, but have checked all the sound output settings, including Audio Midi, and they are all set to output to the DAC and mute is off. Looking on t'interweb I've also reset the PRAM and SCM without success.
I'm now pretty much at the end of my tether, having exhausted every option I know about.
Anyone out there who is more technically minded or experienced on Mac's who can help?
