Results 1 to 10 of 20
Thread: Croft pre stepped attenuator
    I'm Carl.
    Default Croft pre stepped attenuator
    Hi,
    I have a Croft pre R S spec but with American octal valves.
    Just wondering if stepped attentuators are worthwhile?
    Thanks
    I'm Manny.
    What's got you wondering?
    I'm Simon.
    I've got one of these in my passive: http://www.acoustic-dimension.com/at...ators-main.htm
    Superb and a big leap up from the tisbury I was using previously (I believe it uses a Dact 21-step).
    Many stepped attenuators have too coarse steps, so you often have difficulty in selecting the exact volume level you require.
    I'm Carl.
    Hi,
    Thanks for replies,
    Noticed a few people recommending DACT in Croft pre amps.
    I would need 2, so nearly £400.
    I was wondering if it was a worthwhile modification.
    Carl
    I'm Carl.
    Thanks for the 41 step link.
    I'm Ian.
    Hi Carl,
    I say with hand on heart, if I owned a Croft RS pre (and I did for a little while), I'd leave it as the designer intended and sit back and enjoy it. I just can't help thinking that a possible outcome is spending the £400, getting the DACTs fitted and then not really noticing any sonic improvement.
    Genuinely not trying to be a bore in suggesting leaving all well alone - sometimes the best thing to do is nothing !
    I'm Carl.
    Thank you.
    Quote Originally Posted by IHP View Post
    I'm inclined to think the same.
    Somewhat off topic, but if I had a spare £400 to play with, I'd be sorely tempted to try this: https://www.ebay.co.uk/itm/Glasshous...IAAOSwT2daO8Hi
    I'm Mick.
    Hi, I ordered one of these last night.
    https://www.ebay.co.uk/itm/Dale-23-S...K/322590212161
    I found that the volume pot on my Croft Epoch was not balanced 20kohm difference between sides, currently Ive bypassed the volume using resistors, big improvement. but no adjustment.
    You could try using resistors to see how big an improvement a stepped device would give.
