Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Mark Grant XLR Canare L4E6S Star Quad Balanced Cable
    MartinT Guest
    Default Mark Grant XLR Canare L4E6S Star Quad Balanced Cable
    I bought a pair of these to try out in place of my no-name OFC balanced cables between phono preamp and main preamp. My system is all-balanced XLR connected and uses mostly Kimber Select hybrid silver cables. However, several price hikes have made them eye-wateringly expensive so I decided to see how a good copper cable sounded.
    The Canare cable that Mark Grant uses is well known in studio circles and features extremely good shielding with its star quad construction using eight cores. Connectors are Neutrik - the best.
    Replacing my existing cables and not allowing for much burn-in, I heard an extra sparkle in the sound. Soundstage was decidedly wider and a little deeper and I could hear 'into' it more clearly. Midrange and vocals are transparent and very neutral. Dynamics are superb. The noise floor is vanishingly low. These cables give every impression of just letting the signal pass through unmolested.
    For the price, I am impressed. It is harder to hear differences between balanced cables as this connection method gives so much clarity in the first place (provided your equipment uses true balanced circuitry) and yet I heard the differences quite clearly. Highly recommended.
    Nice one, Martin
    Should I bring down some G1000HDs on Saturday to test against your Kimber Selects?
    Remember what happened to my ludicrously expensive Transparents, which the Mark Grants duly retired....
    MartinT Guest
    No good - all my cables are balanced XLR and I believe the G1000HDs are single-ended. Don't even try to compare the two, balanced sounds far superior in my system.
    Anyway, aren't we playing with turntables? <rubs hands with glee>
    Yes, good point! Might be worth a laugh though asking Mark to make up some balanced G1000HDs to compare them with the Kimbers
    Turntables? Oh yes indeedy! Steve W visited today and, erm, how shall I put it, 'quite liked' the Techy compared with his LP12...
    Btw, as an aside, how efficient are your Ushers and are they liable to be a tricky load for a valve amp?
    MartinT Guest
    Quite efficient, but they may be a bastard load especially as they have two bass drivers per side. Of course, the Chord doesn't even blink
    My Heco Celan 700 speakers have two drivers aside. My Copper amp (same as Marco's) doesn't blink. If they are ~89dB + and 6 to 8 ohm-ish the Copper amp shouldn't have a problem.
    They are in a different league to my Hecos though.
    The specs are as follows:
    Usher Dancer Be-20 speakers
    Technical Specification
    3-way Floor standing 1.25" BeO dome tweeter and 5" BeO inverted dome mid, and 2x11" low woofer
    Sensitivity 90dB @ 1watt/1m
    nominal impedance 8 ohms
    frequency response 22Hz - 40Khz (+/- 3dB)
    power handling range60 - 300 watts
    crossover frequencies 544Hz and 3.84 Khz
    weight 123Kgs (inc base) (foookin' elll!)
    dimensions (wxdxh) 36.5 cm x 89.5 cm x 140 cm
    http://www.hiaudio.co.uk/UA/Be20.htm
    Wink
    In my personal experience the Ushers will work fine with a valve amp. I have used 2A3 to PP 300B no problem. But they are designed for high power amplifiers to get the dynamic range in a big USA rooms.
    Dave
    That's good enough for me, chaps... Then I may as well bring the Croft and copper amp down for a giggle
    You'll need the G1000HDs then as you can't plug XLRs into your amps.
    leo's Avatar
    leo is offline Circuit Junkie & DIY Room Forum Leader
    Keep us updated, be quite an interesting comparison copper valve amp against the Chord
    Cheers,
    Leo
