Just wondering how I connect my Nak ca-5 pre amp to my Sony TA-F670ES integrated amp, so I can use the Nak as a phono stage. Ta.
think most use the tape out
tape out of the nak.(to an input on sony) i usually just took the output of the nak to the amp using just the phono, and adjusted the vc, but if you use the tape out you will bypass the pre
I use the preamp output on the Nak to the aux input on my MF integrated and use the Nak's volume control to balance the sound level.
Turntable
CD
Network Player
Cambridge NP30
Amplifier
Speakers
Cables
Headphones
bypass the nak pre. then youll just use the sony pre. i just used both ..ie nak output to say aux set nak vc to where it was level with the other inputs.. but most folk take the nak output from the tape... both ways sounded fine to me
i use mine the same way as ian.
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
Throw the Nakamichi in the bin...
My System
John Wood KT88 Amp.
