Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Warm sounding Power amp
    Location: Dutch now living in Milton Keynes in the United Kingdom
    I'm Rob.
    Post Warm sounding Power amp
    Hi Guys, I am streaming music via usb, to a musical fidelity V90 dac, to a Nobsound ns-01P tube pre amp and then to a arcam Alpha 8 power amp.
    I have the idea that my power amp is the weakest link, although my friend Chris (Lerxst) has a different system with a similar sound, we both have the Q Acoustics 2030 speakers.
    I heard that some on this forum find the Arcam Alpha 8 Harsh, I don't have that idea but I think I am missing some oomph especially when you playing on a lower volume.
    What would be a nice warm sounding budget power amp, All cabling are chord company interlink cables and speaker cables.
    I'm tony.
    behringer a500.
    A big softie with lots of oomph for not too much dough!
    I'm tony.
    Some mark grant interconnects and van damme speaker wire may also help-chord stuff can be a bit up front.
    Quad 303?
    And I agree with Tony. Experimenting with cables can help.
    Hi Rob,
    Getting dissatified already?
    I bet you had the same thought as I did when Tony mentioned cabling...
    Chris
    I'm Rob.
    Hi Chris, I was more thinking of replacing my power amp, I can sell the Arcam Alpha pre and power amp as a set, the pre amp hasn't been used since I have my little tube amp. For now I am only looking around, but the audio bug never stops, and I don't find the sound warm enough. so if someone is interested in a swap for a warm sounding poweramp with my Arcam set I will be interested.
    I am very interested if that cable swap makes a big difference.
    I'm Phil.
    mmm never heard arcam described as harsh ever , heard a lovely arcam system recently and it was very natural . the owner has just upgraded higher up arcam tree , might be worth thinking about the integrated or the power amp . the chap is a really great guy
    i also had several arcam products i.e p1 , c31 , a22 and they were never harsh
    https://hifiwigwam.com/megastore/pro...m-a38-and-p38/
    Eric Bibb
    I'm Rob.
    I just read it somewhere, I don't find the sound harsh, bit I think the Alpha 8 is a bit of a lightweight for the system, they compared the Alpha 8 with the alpha 10, the alpha 8 is 50 watts and the Q Acoustics are 6 ohm, as budget Hifi enthusiast you always try to improve the system a bit.
    Hi Rob,
    I don't think you have a bad amp there and it is on the warm side of neutral I think. It is a bit under under-powered maybe (40 or 50 wpc?) but Your 3050s are 6 ohm speakers and quite easy to drive. Your Nobsound / Arcam combo is not going to be harsh, surely?
    I saw you posted another article about usb cables.
    Maybe have a look at a good usb cable from laptop to dac first? Your nice cable was eaten by the dog or something, right?
    Just a thought
    Crossed lines there. Great minds...
