Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 117
Thread: Terrible internet speed
  1. #81
    Ah I see... In terms of fibre-optic, why not? You're in London, not the back of beyond!
    Might as well be. It's a private estate with very few homes in it. They won't spend to lay optical here yet.
  2. #82
    I see, well you never know
  3. #83
    Thumbs up Amazing broadband speed...
    From before:
    We've just moved from Sky, to the 'VIP package' with Virgin, for half the price!
    £88 a month including line rental, plus all your calls, weekday and weekends, including to mobiles, 350Mbps (Vivid ultra-fast, fibre-optic cable, direct to house) broadband, full Sky package, plus Movies and Sports (both Sky and BT[HD]).
    As shown below, I currently get around 60Mbps download speed, with Sky, so can't wait to do a ping test after the Virgin install has gone through!
    Had the Virgin lads in today to carry out the install (thoroughly nice guys and very professional), took a couple of hours to get it all in and set-up. Anyway, I've just done another speed test, after the switch to Vivid 350Mbps ultra-fast broadband (compare the following with the above):
    Seems reasonably quick...
  4. #84
    You can't fault the old fibre-optic.
  5. #85
    It's mental, mate. Movies download virtually not much after you've hit the button, just crazy-fast!!
    Plus, for whatever reason, the (already excellent) picture quality with the previous Sky Q box has been notably bettered, in terms of resolution and clarity, perhaps because it wasn't fully 4K HDR compatible, which the Virgin V6 box is, so that was a nice free upgrade!
    I'll be doing a separate write-up about that in the AV section.
  6. #86
    Mine improved a lot when they put the V6 in. Much sharper.
  7. #87
    One other thought is that it might not just be as a result of the V6, but also the fibre-optic cable, or moreover, receiving a TV signal underground (optimised through 'fibre-to-the-home'), as opposed to via a satellite dish?
  8. #88
    It could be a contributor but I've had fibre optic since 1996 so in my case the improvement can only be down to the new box.
  9. #89
    Have you done a speed test recently? If not, could you do one and publish the results, as I'd like to see what you're getting with your fibre-optic
    Click here: http://www.speedtest.net/
  10. #90
    That's via wireless.
