Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 117
Thread: Terrible internet speed
  1. #21
    I'm Jon.
    In BT's defence, the line comes into the premises, and they are not responsible for any internal extension cabling. Their responsibility stops at the master socket.
    BT no longer fit extension cabling, and haven't done so for at least 25 years.
    Householders are notoriously tight fisted, and would rather fuck it up cobble it together themselves, rather than pay someone who knows what they're doing.
    It's the same with wired data network cabling - they'll do everything they can to avoid putting their hands in their pocket and get the job done properly.
    You've had someone who knows what they're doing look at yours, so you are very definitely in the minority.
    As a result of changes introduced relatively recently, and slipped in beneath most people's radar, the point at which a service provider responsibility stops has been shifted back to the boundary of the the property at which the service is provided.
    In our neck of the woods the phone lines are above ground and when we had a problem mid-2017 they claimed that the fault was located at point between an imaginary vertical rising at our boundary and the master socket and hence could not be repaired FOC. I argued until I was blue in the face (and arse, for that matter) and got nowhere. I imagine that the same rule now applies to underground feeds.
    Yet further evidence, not that any more was needed, that OFCOM exists to protect the best interests of BT/Openreach and their investors and not those of the consumer.
    Jon
  2. #22
    Quote Originally Posted by MikeMusic View Post
    That was about the speed we used to have. We are up a country lane, off another and some way distant from the exchange.
    Fortunately for us we eventually had a BT engineer who really looked for the problem.
    Took a long time and I was helping
    Turns out the 'Master socket' was not.
    Some Heath Robinson work by him got the real master socket going.
    Bingo 12Mb and getting faster.
    Next time you have BT in speak to him on the QT and see if he will come in and fix it - with you paying him of course.
    That was the way I was going to go before we had the ace guy in
    You may have tried these things, but I'll say them anyway, just in case.
    Good point about the master socket. You need to be plugged into that directly with a short cable, not upstairs in the bedroom socket or on an extender cable.
    Tried a different RJ11 (telephone) cable between router and master socket? A bad one will break it. Stupid £2 cable can ruin everything.
    Unscrew the front of the master socket and if there is a socket inside there, plug into that. Any better?
    Firmware updates on a router can help a bit but not much. Try a different router? Sure you have the correct power supply for the router?
    Are there any power cables which are next to the phone cable? Move them away if you can.
    Have you got many devices on that one line? Too many will not be good. None except router is best.
    Also, if using those homeplug things, try plugging into the router itself. Those homeplugs are pretty dodgy at the best of times.
    How are the electrics in your house? That may have an effect - some mains products may be able to iron it out if it is up and down.
    Can't think of anything else the moment...
  3. #23
    Thanks for all the tips but over the past 10 years, we have tried everything and been visited on several occasions by BT engineers. Trouble is, the long run from cabinet to house and BT will not do anything about that.
    A couple of people have kindly sent me links or screenshots of the Openreach website where they show that our cabinet has been upgraded. This was done a few months ago and since then we have had slower speeds and even lost Broadband twice for several days. Each time we phone BT we go through the same rigmarole of plugging a cable into the router etc to check the abysmal speed and each time they say it's within acceptable limits at just over 1 Mb.
    I have contacted a couple of other providers who confirmed that they wouldn't be able to improve the speed as they would just be using BT equipment, so don't change.
    Our MP wasn't the slightest bit interested and what I would like to know is - who can I complain to ?
  4. #24
    I'm Jonathan.
    I fully sympathise. Living about 3 miles from our 'upgraded' cabinet means that we still had 512kbps over the landline.
    We contacted some wireless providers and as they might have been interested they would need several customers to sign up before taking any further steps. They are however starting to make inroads into the more remote areas including businesses that can't get a decent BT service.
    We did find however that both EE and Vodafone had upgraded their networks locally and although our phones could not pick up a signal in the house, an external 4g aerial and a SIM based router solved the problem. We get a minimum of 15mbps download and sometimes as high as 45mbps. As an existing EE customer this was easy to test with an existing SIM, although there is a monthly data cap we don't go over.
    Kit from Broadbandbuyer.co.uk was easy to set up.
  5. #25
    Can't answer your question about to whom you should complain but check out satellite broadband. It is not that expensive for a home setup. Europasat offer it but there are other providers. It doesn't use your phone line. Just had a quick look around and you should be able to get 10 mbps or more for about a tenner per month
  6. #26
    I'm Neil.
    Sounds to me like satellite broadband will be the best solution here, and it is far far far cheaper than it used to be. Bypass line issues altogether.
  8. #28
    Govt will subsidise your setup by up to 400 pounds if ur under 2 mb
    https://www.satelliteinternet.co.uk/new-packages
    An update.
    Earlier this week, we received a card from Openreach to inform us that our green box has been connected by fibre and our internet speed should improve. My Wife has done a lot of phoning around and online chat and we have now signed up for Unlimited BT Infinity, which promises between 19Mbps and 30Mbps. Yippee..
    I'm not sure I believe them, so we will wait and see.
  10. #30
    I'm Anto.
    How far are you from the cabinet Dave?
    We are in the sticks but they put fibre into the cabinet that is maybe 800 yds from our house. Its still on copper wire , but that distance is good for the full Monty whereas the further away you get it starts to drop like a stone due to the resistance in the copper I assume ??
    Hope you are nearby it
