Ah well. I was going by my ears. I have low and normal ZYX MC's and can't hear much between them.
You're right, it doesn't amount to a great deal of difference in practical terms. The phonostage should cope ok.
JFET MC phono stage is still here.
It's been a popular phono stage and well regarded on the DIY Audio site with more than one group buy of the PCB's.
I know DIY stuff is often difficult to sell as prospective buyers can be put off because of potential resale value. With that in mind I'm prepared to offer it on a 'sale or return' basis for any AOS/PFM forum regulars who are interested to try it out in their system.
However as its a two box construction, and quite bulky, I'd prefer audition and collection from South Northants or I can meet up / deliver within 50 miles of NN13.
Postage at cost is fine for an outright sale though.
I'm Sandro.
I have built that myself
It is pretty good for the money and you have used more than decent components, for what you are asking you lucky to break even
IMO worth a listen ...
I have not heard the Rothwell head amp But had the great pleasure to ear the signature 1 and signature 2 and those are really good...
In regard to the gain it may be adjustable a bit mine work fine whit the Goldring Elite I also had built the Older Sallas Simplistic and doubled the input Jfets but still one has the amplifier knob to play whit
It is worth a listen and sale or return ... can't go wrong really
Now reduced to £275 plus postage.
I'm Slim.
If your cartridge has an internal impedance of 40 ohms then the load should be approximately ten times that, at around 400 ohms.
In my experience it’s not that critical with most MC cartridges.
The loading in the Salas phono is adjustable with small DIP switches and I’m pretty sure you will find a load the Denon will be happy with.
A hiss problem is not usually anything to do with the load that cartridge is working into. What phono stage are you using at the moment?
I'm Slim.
