Results 11 to 20 of 24
Thread: spotify control question
    I'm Andy.
    Quote Originally Posted by Crackles View Post
    Can you explain this in more detail? I don't understand anything about Rasberry PIs. Is the dac built in? If so can a PI transmit via Bluetooth? Does it have Wifi and can you download apps? (I use Deezer). Thanks
    All good questions.
    The PI is a bare bones mini computer with everything included on the board (latest version has Ethernet/Wifi, 4 USB ports, HDMI out, 5V power micro USB in and also 3.5mm audio out.
    Most people bypass the audio out as very noisy so install a DAC which you then connect to your amp.
    With the PI connected to the network (either cable or Wifi) you can then control it.
    You need to down load and install the operating system and in the case of Moode or Volumio, the OS also installs the music interface.
    Regards Bluetooth - you can buy a USB Bluetooth dongle and and using the native OS you can stream music to it, but not sure if Moode or Volumio would work with it as not my modus operandi!!
    Hope this helps!
    Main system:
    Digital.
    Raspberry PI plus IQAudio DAC+. Philips DCC 730. NAS drive plus usb drives connected to the router.
    Analogue.
    Michell Orbe with arm decoupling kit. AudioNote Arm 1 V2. Goldring Elite MC and Cairn Boost
    Amp. Pure Sound A30
    Speakers. Reiver Jenna floor standers
    Spare system:
    Audiolab 8000a. 3 Lenco L75 turntables, assorted cartridges and arms. Garrard SP25 mk2.
    Loads of different cables of various value....
    I'm Phil.
    Quote Originally Posted by diviy View Post
    cheers all new to Spotify and first time I started it up on phone and tablet at the same time and it give the option to listen on one and select tracks and control the second with it no volume remote only down side but well happy
    i use a sonos system with a controller as i have no smartphone . piece of cake to use and remote control works well
    1]bel canto pre 3 vbs /MSB s200 , / Marantz sa8005/ bel canto fm1
    sonos, . tannoy eaton legacy 2]velleman 8020 pre , firebottle mono`s onkyo sacd bel canto 3.5vbss and RFC impulse ta`us , track audio stands
    I'm John.
    Quote Originally Posted by gninnam View Post
    All good questions.
    Hope this helps!
    Cheers for this, appreciate it. It does sound appealing, but the problem I have at the moment is using a DAC and Bluetooth to headphones at the same time. I use Deezer from my Galaxy S6, sometimes to BT headphones but that obviously means using the phone's own DAC. I much prefer using my Fiio DAC but this will only work with wired headphones. It also presents the problem that the phone has only one USB port so I can't charge the phone at the same time as using an external DAC.
    Ideally I want to stream Deezer via wifi to a portable device with a decent onboard DAC that will transmit out via bluetooth. Could I use the Deezer app with the operating systems you mentioned?
    I'm Will.
    Have you considered a Chromecast Audio? An excellent streaming solution if you don't want any local file streaming...
    I use a network of raspberry pis and squeezebox clients, running LMS/piCorePlayer on the pi's, overall a very flexible solution, but a bit OTT if all you want is to stream Deezer, controlled via an Android phone...try a CCA
    Cheers, Will
    I'm John.
    Quote Originally Posted by WAD62 View Post
    I use a network og raspberry pis and squeezebox clients, running LMS/piCorePlayer on the pi's, overall a very flexible solution, but a bit OTT if all you want is to stream Deezer, controlled via an Android phone, try a CCA
    I've got a Chromecast audio, which I sometimes use to stream Deezer to my HiFi. It can be temperamental using it that way but mostly works well. It won't work to get sound to my headphones though. The reason I want a fully portable option is because when I'm listening to music in the kitchen or whatever I am moving about hence the need for Bluetooth. Hope that makes sense.
    I'm Will.
    Oops I should have read the first page...so you need blue tooth in, and out
    What about this?
    https://www.amazon.co.uk/FiiO-BTR1-B.../dp/B075YD83Y9
    Cheers, Will
    I'm John.
    What about this?
    I don't need bluetooth in, just out. Wi-Fi is fine on the way in...however, that Fiio looks brilliant! I didn't know they did a Bluetooth amp, and it says it has a DAC on board too. I love the performance of my Fiio E18 (even if the battery life is a bit poor) so I will definitely look into this. Cheers.
    Default spotify control question
    Best Bluetooth units Ive used are the class1 Avantree units. One I have has pass through and analogue or digital in. That's if your happy to go to a 2 box system but opens up your options
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/M55E/EMOTIVA XPS1 - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER24, DEEZER HiFi - SMSL M6 MINIDAC - RPI/AUDIOPHONICS - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
    I'm John.
    Have you got a link to this?
    The thing I don't understand is how a phone or whatever can transmit an unconceverted digital signal to a DAC. I thought the signal sent to a Bluetooth receiver was already converted to analogue? It seems that the Fiio unit takes digital data via bluetooth then converts it to analogue. How does the source know whether to do the analogue conversion on board or not?
    http://www.avantree.com/long-range-b...ree-oasis.html
    You can get it on amazon
    Used low latency too so no sync probs. About 50 a pop tho
    Grant ....
