Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 66
Thread: Help with my Tannoys
    if whole speaker is dead check amp for a line fuse or trip
    I'm Adrian.
    I've been trying to call Tannoy for a few days as well, all you get is some German woman with a recorded message, then regardless of what button you press it just rings out.
    Been trying to source a set of boxes for Eatons. In the old days if you called Coatbridge, someone in Coatbridge picked up the phone.
    Do you have a number Tom?
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
    montesquieu Guest
    Quote Originally Posted by farflungstar View Post
    All you get is the same switchboard regardless which option you press - the number I'd been trying is 01236 420199
    Try contacting them via their official Facebook page.
    I've been having a think about this;
    It could be a resistor in the cross-over which has gone open circuit, due posibly through high power distortion, or some kind of parasitic oscillation, I seem to remember you saying you had a noise in the system prior to switching the high frequency unit back to its Neutral position ?
    Just a thought.
    A...
    Nikola Tesla
    www.tubedistinctions.co.uk
    Matthew 5:10
    I'm Adrian.
    8 minutes waiting. Gave up. Not cheap calling from Spain.
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    I'm Adrian.
    Quote Originally Posted by anthonyTD View Post
    Just a thought.
    A...
    Yes - Lisa Gerrard, two certain notes incredibly powerful and at the same time a buzz from the tweeter. Looking at the crossover the level control isnt resistors it's an autoformer - but I couldn't quite understand the rolloff circuit. I will take it out again tomorrow and photo it and upload it.
    But, how could the resistors (?) Have gone open if they were not in circuit (supposedly as the rolloff wouldn't be using those).
    Bugger.
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Could be a dodgy soldered joint. If you have a meter, checking continuity and component values should be easy enough.
    montesquieu Guest
    Fine if you have facebook.
    I'm Adrian.
    Tom you can't message them on Facebook either.
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
