Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Solder
    I'm Philip.
    Quote Originally Posted by agk View Post
    All sound advice. If you get stuck Phil or just want a hand I'm only in Peterborough.
    Thank you, that's very kind.
    I'm Philip.
    Thanks again for the replies.
    Though, having found a picture of the inside of the fixing posts, in seems the cross over is more or less stuck on the back of it.
    So, i might leave this to the pros.
    My curiosity is live now. What speakers are you looking at?
    I'm Philip.
    I have some recapped ms pageant 2.
    The bare wire connections are the work of the cevil.
    I haven’t been able to listen to tnem yet.
    Hopefully tomorrow that will change.
    Longer term, i’d also like to try something like some old jbl l26, etc.
    I'm Alex.
    I use the WBT-0820 and 0840 range. It has 4% silver content and the usual Tin/Lead mix so melts at 178-180ºC and is very easy to use.
    Care to share the picture Philip? I have had a look at a few and it looks possible but it may be that you've found a better shot.
