I'm nigel.
Watford Valves offer a few kits of matched tubes for Little Dot range, each with its own particular sound...and price
I currently use a MK3 with a set costing under 35quid purely as a preamp.
It's way better than its price point would suggest....quite shockingly so.
Of course the single RCA input could be an issue....I route all my sources digitally through a DAC.
It warms them up nicely.
I'm waiting for my delivery of several matched sets of Russian gold pin EV valves for the LD mk2/3 maybe they also work on the 4. Will report back with findings and can sell on a couple of them if they work nicely.
I'm Andy.
Hmm. Do I wait for one that is reported as having no issues or, like you say, take a punt..............
Decisions, decisions!
Main system:
Analogue.
Network Player.
Digital.
Philips DCC 730 player
Marantz CD50SE
Amp.
Audiolab 8000A
Speakers.
Reiver Jenna floor standers
HeadPhones.
I have 2 little dots MK II and MK IV. They all take the same kind of valves - Watford valves do a few kits, yes.
Ask the guy selling it if he swaps the left and right valves over (big ones, test, then little ones, test) does it now buzz from a different channel? If so, it's the valve or valve connectors - maybe corroded. If not there is something else wrong. If the fomer, go for it, if the latter, leave it. Be aware a whole new valve set with a halfway decent set of valves, even unmatched, costs about £85, with VAT, which Watford Valves don't seem to mention until it is checkout time on their webpage.
These things are massive value for money - upto the MK IV (not the SE). They are asking almost regular prices after those models.
If it's the socket, the problem won't follow the valve. I could do my valve sets for about £25 plus postage!
I'm Andy.
I know in the add he is shipping it with other valves so I assume that the problem isn't these.
After the unit has warmed up the noise goes so could be caused by a poor solder or connection (once warmed up the sound goes)?
Cheers
Main system:
Analogue.
Network Player.
Digital.
Marantz CD50SE
Amp.
Audiolab 8000A
Speakers.
HeadPhones.
I'm Andy.
Just got this from the vendor when asked about moving the valves:
"I have yes. If you tap the case of the amp lightly the buzz disappears temporarily until warm"
Main system:
Analogue.
Network Player.
Digital.
Marantz CD50SE
Amp.
Audiolab 8000A
Speakers.
HeadPhones.
Probably dry solder joint.occasionally I think a dodgy capacitor can do this too?
I'm Andy.
Punt or not - that is the question.
Currently sat at £52 with 2 hours to go - if it goes over £80 then I think I should hang on for one with no issues so will make a bid in the next few hours and see where we end up!
Main system:
Analogue.
Network Player.
Digital.
Marantz CD50SE
Amp.
Audiolab 8000A
Speakers.
HeadPhones.
