Originally Posted by
Edwardlon
So despite grand plans to build state of the art cabinets for these little supertweeters and a PM recommendation for a unique solution I've ordered bog standard wooden pencil cases to house this. The size (
20cm x 6cm x 4cm) is perfect to fit on top of the speakers. So judicious use of a stanley knife, low speed drill, solder, thin wire, furniture protectors etc I will be done. Why go high when you can go low (cost).
So if I detect lots of resonance I can fill the case with - um - lead pencils.
Sounds like exactly the same idea I had when I mounted mine on my Tannoys. Total project time, about 15 minutes!
