Results 1 to 10 of 11
Thread: My humble system
    I'm gerald.
    Default My humble system
    Custom built SL1210 pitch slider .45`s adapter and cue light all removed and filled and covered in carbon fibre wrap
    Timestep power supply,Ian mac bearing ,Achromat, Kab fluid dampner,ADC LM1 headshell ,hockey puck with a 7mm hole as a clamp and Isonoe feet added .
    Custom pre passive pre amp with volume and selction controls Four inputs and two amp outlets one to amps other to headphone amp.
    Custom made phono stage running three JJ803 valves has two power supplies one custom built and a 6.3dc walmart supply for the the heaters .
    Custom made power supply for phono stage
    Custom made case for Time step power supply for my deck
    All cases hand made and all design and building done by my friend Jason who used no pcb`s only turret boards and point to point wireing ,Also waiting for mono blocks being built plus a few other items in the pipeline
    All interconnect cables Klotz mc 5000 cable
    current amp`s Arcam p8 x 2 headphone amp is a music fidelity X-can, Speakers Ditton 15xr speakers with rebuilt crossovers and upgraded speaker input`s
    Jason does gooooood work. Nice toys man.
    I'm Russell.
    Awesome stuff Gerald! I do love the case on your phono preamp! With the connections on top, makes good sense.
    Photobucket does not allow any third party hosting so your pics are blank
    Can you find another. I use Imgur which is fairly straightforward
    Lumley Heliosphere Audiomods 5
    Hovland HP200 MC
    Hovland Radia
    Ming Da 805 monos
    Magnum Dynalab Etude, RWA Cassabria + LCD 3
    Wilson Benesch Actors
    Very impressive
    Hovland HP200 MC
    Hovland Radia
    Ming Da 805 monos
    Where did you get the invisible headshell and cartridge from? Must make setting up a nightmare
    Looks superb
    I'm gerald.
    Finally got system all set up so the question how does it sound ?
    My old set up sounded really good to me but then when the pre/Phono stage died after speaking to Jason he said he will see what he could do .
    Today finally go a good run of albums playing had to reposition speakers loads of times after finally being happy with balance I have sat down and had a proper listen .
    To my ears what a massive improvement the bass on Nevermind is smashing my internal organs up the treble is pure bliss .
    Image separation and clarity I have never heard before .So not bad for a system that's been built on a tiny budget over the years !
    Roll on the Mono blocks
    One very happy man who can t stop playing lp's at the moment
    I'm guy.
    worth it for the transparency
    I'm Paul.
    is that a Hockey puck on your turntable ?
