I'm Deleted.
ive not noticed any speed difference yet,well at least to my ears anyway.
i must check it with a phone app
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
I'm Deleted.
Well I don’t know how accurate your phone app is but I have a very accurate strobe and the effect of adjusting oil viscosity is easily measurable. Irrespective of how important (or otherwise) one feels measurements are, in this case, speed changes will affect pitch.
Account Deleted
i used to run thick silicon oil when my deck had a stiff Ac controller on it. With my DC supply the logic that controls the speed correction gets upset if you go too thick. Going from 5k to 10k was enough to cause the speed to drop maybe 1-2 segments per rev of a 150 segment strobe disc, audible? Maybe just.
I'm Deleted.
Yes, perhaps I should add that I run very thick silicone oil.
Account Deleted
perhaps a better application for me would be silicone oil for the top and sides of the spindle and oil for the bronze bush and well? remember its inverted.
My System
John Wood KT88 Amp.
There is some stuff Shell make called WOM (White Oil Medical). Don't worry about finding it - buy Johnson's baby oil. It is that mineral oil with perfume. It is low viscosity and will not be affected by any normal variations in room temperature. You can get simple low viscosity technical white oils (WOT) without perfume on Amazon for pennies.If you want a viscosity figure go for "Tech 30" or simply "30".
The Medical grade is for contact with people. WOM or WOT, it is the same stuff for your purposes.
The reason I would say this is better is because it is low viscosity, pure unadulterated oil. It will not clog up due to additions to the product (although dust etc will clog anything up). And it is dirt cheap.
Use very little!
Also tend to agree with this. Thin oil will run on longer when the power is removed, but is this attribute serving any beneficial purpose?
The quite considerable force on the tip of the thrust bearing requires an oil capable of preventing wear, which is more relevant.
I now prefer more viscus oils which give the motor something to push against and tends to damp out rapid speed fluctuations.
My current bearing (Pro-Ject RPM 9) in my Technics hybrid deck is running on Castrol LM grease and is as steady as a rock.
A lot will depend on what the bearing was designed to run on in this particular application, stick to the original or similar, but don't waste money on exotic stuff.
I saw a couple of GL75 decks as part of job lots in an auction last week, don't know what they brought as I had to leave before they came up.
I had a collaro 2010 that sounded like a road roller until I put a heavy engine oil in then it was silent. How long the platter kept spinning was of no interest
