Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Wanted: modestly priced subwoofer
    montesquieu Guest
    Default Wanted: modestly priced subwoofer
    The Tannoy DC6es in my study start to drop off at around 50hz, I'm looking for a modestly priced sub that will fill in from about 30-35hz.
    Budget about £100-150. Cosmetic condition more or less irrelevant. Single RCA input is fine I don't need high level.
    Anyone got something kicking around?
    Are you sure single RCA is ok, do you have an AV amp or a processor that will combine a stereo bass signal into a mono? If not and you take L or R out, you risk an odd tonal balance on some recordings eg Kind of Blue where the bass is on one side IIRC
    montesquieu Guest
    I have a 'mix down to mono' reverse splitter, impedance matched, that Nick Gorham made for me in my days playing with a dedicated mono system. I'll use the output from the second set of output sockets on the Pass B1, combine them and send them down to the sub. Of course if it requires stereo input that it then mixes down itself, I can run stereo sub cables.
    I know this is more than your budget Tom but have you seen this?
    http://theartofsound.net/forum/showt...in-piano-black
    montesquieu Guest
    Thanks James yes I did see it but it's going in a study setup where the Class D power amp was £100, Pass B1 pre another couple of hundred, and around the same again for the little Tannoys. I can't justify a sub that cost the same as the rest of the system.
    I had an MJ Acoustics sub which was pretty good
    They can be picked up for about £70
    Bev
    Yes the MJ acoustics ref something I had was brilliant, compact and less than £100 used.
    I think mine was the Pro 50 and it was good and small enough the 'hide'..
    Bev
    montesquieu Guest
    still looking
    Not sure if this is still available, but may be of interest?
    http://www.pinkfishmedia.net/forum/t...woofer.208127/
