Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Caiman SEG with battery / Linear PSU
    I'm Bill.
    Default Caiman SEG with battery / Linear PSU
    I'm on the lookout for a second-hand 15v Linear PSU, but am also considering battery options.
    I'd like to know whether a battery can or does run at 15v? I'm thinking something from Anker rather than a car type battery.
    A secondary benefit with the Anker is that I could also power my Chromecast with it at the same time.
    Quote Originally Posted by Bourneendboy View Post
    Not sure if its what you are looking for but I bought a usb cable that converts the 5v usb output of my Anker (type) battery to 12v. Works fine with SEG which has tiny current drain. Not sure if you can get a 15v usb adapter?
    Geoff
    Geoo
    I'm Bill.
    Geoff
    Geoo
    Could you post a link to one please Geoff as I'm not sure what you mean
    I'm Bill.
    Cheers Geoff!
    I'm peter.
    Hi Bill
    Deben tracer after that you won’t even think about another power source JOB SORTED!!!!
    Apologies for the light on the photo
    HEGEL H100 integrated amp
    REGA rp6/exact cart
    REGA Apollo r CD
    NEAT ELITE SE loudspeakers
    BERESFORD bushmaster mk2 dac
    Powered by a DEBEN tracer battery
    Mc5000 klotz ms audio cables(cheers Brian).
    REGA couple 2 ics
    JEZ ARKLESS phono stage
    RUSS ANDREWS powermax mains cables
    ISOTEK POLARIS mains block
    ATLAS Speaker cables
    CREEK OBH21 SE head amp
    BRIANS silver hybrid ics
    I'm peter.
    Here’s a link
    https://www.tracerpower.com/12v-8ah-...tery-pack.html
    REGA rp6/exact cart
    REGA Apollo r CD
    REGA couple 2 ics
    I'm Alastair.
    I use a Tracer LiFePO4 12V 16Ah battery to power my Caiman SEG (as well as two of my monoblocks). It lasts a couple of weeks between charges - I turn it all off when not in use. Note: you cannot trickle charge the LiPO4 batteries.
    I am sure a smaller capacity, cheaper version, like this one, https://www.tracerpower.com/tracer-1...4-battery.html, would do just fine for the Caiman alone. LiFePO4 (Lithium Iron Phosphate) are the safest Lithium batteries and should have a much longer life (1400 discharge cycles vs. 300 for LiPo). I gave up on LiPo for the monoblocks when one of them swelled-up and died (although I still use the Ankaka battery to power my RPi) and I didn't like the idea of big lead-acid batteries in the house.
    Cheers
    Alastair
    RPI4/PI2AES running PiCorePlayer/LMS-> AQ Carbon AES -> Topping D90 DAC-> Khozomo Passive Pre-Amp -> 4x Temple Audio Monoblocks powered by 2xLiFePO batteries->Van Damme Black Bi-Wired to B&W 804 Nautilus and Sommer Carbokab 225 Interconnects
    I'm Bill.
    Interesting stuff - will have a read up!
    If I were to run on 15v, does the SEG have to be modified in anyway?
    I'm Alastair.
    I was running mine with a 15V linear PSU without modifications and no problems before I went to the LiFePO4 battery. I seem to recall Stanley Beresford says they are good to 16V, so 15V should be safe.
    Cheers
    Alastair
