Results 1 to 10 of 12
Thread: Small (passive) speaker recommendation
    I'm Edward.
    Default Small (passive) speaker recommendation
    Looking for ideas on a speaker recommendation please.
    This for my study/dining room and due to layout needs to be table/bookshelf mounted (so no rear ports, stands etc).
    Currently (and indeed for years) have been using an ancient Acoustic Research 8BX which was restored/upgraded by Wembley Loudspeaker also ages ago. Fairly open and detailed sound but not 'emotional' and involving enough. Especially when compared to the Kudos or PMCs I use in the main room.
    The AR 8BX measure 40/24/18 (h/w/d in cm) so looking for something up to that size, ideally smaller. Looking for used, but for now don't want to open a WTD thread, just seeking ideas.
    cheers
    I'm the'greatunwashed'.
    Pretty essential to give an idea of your budget here Edward, lots to choose from
    I'm Clive.
    These are good and easy to drive as they are a single driver (no crossover).
    http://markaudio-sota.us/cesti-mb/
    Notwithstanding your comment about ports, these are specifically designed for desktop use.
    https://www.divineaudio.co.uk/omega-...-speakers-pair
    If your budget is lower I can thoroughly endorse Martin Logan Motion 2 or Motion 4 models. I have a pair of the Motion 2 and they are awesome. Bought them as part of my updated travelling hifi. Used with a Nuforce Icon amp the setup fits into a case not much large than a shoebox. Fantastic speed, detail and dynamics. These are serious speakers. Yes bass output is limited but with reinforcement from a back wall and desktop they do not sound lightweight.
    https://hometheaterreview.com/martin...stem-reviewed/
    Geoff
    I'm Edward.
    Quote Originally Posted by Tim View Post
    You are right Tim. I intentionally left that piece out as I'm flexible. Let's say max a 'few' hundred, but not 'several'. I have a knack of convincing myself of going just a bit further so I will need to resist as they will not be the main listening speakers.
    Quote Originally Posted by Clive View Post
    Ooo they look lovely. I will dig deeper on those Clive. Bit expensive but maybe second hand more reasonable.
    I'm Edward.
    Geoff
    Thanks Geoff. The Motion 2 (or perhaps Motion 4) looks like an interesting alternative. Combined with something like the Nuforce Icon it would also solve the issue of what I do when away from home. I could throw them in the car and still have decent music.
    Quote Originally Posted by Edwardlon View Post
    Edward,
    If I had not been looking for a portable speaker, I might have gone for the Motion 4 which has somewhat more bass extension. However, both speakers share the same Air Motion tweeter which is what elevates this from a PC speaker to a hifi speaker. Both designs come with a neat wall mounting dongle that allows for downward firing of the speaker towards the listening position, and some users place these high up to get bass reinforcement from wall/ceiling boundaries. What I love about them is their dynamics and speed.. I would imagine that they would work well with a small subwoofer, but frankly when not travelling they are used in a bedroom system and sound great.
    They also work very well with this https://www.amazon.co.uk/Nobsound-Bl...ooth+amp&psc=1 though it is important to use it with a power supply rated at least 4amp, ideally 5amp. The bluetooth facility makes it a cinch to stream music from a phone or tablet.
    Geoff
    I have a knack of convincing myself of going just a bit further so I will need to resist . . .
    Haha, I hear you - I fall foul of that in pretty much everything I do in life!
    I'm Neil.
    I would get a pair of Royd Merlins. Couple of pairs up on eBay at the moment. Wickedly musical speakers, involving and fast. They don’t come up for sale that often.
    Or my sub-£100 choice: a pair of old-style Mission 780SE.
    Absolutely.
