I've just bought a Caiman Seg and would like to try a 15v Linear PSU. Before I pull the trigger on one of the Chinese ones, thought I'd check here first to see if anyone has one to move on.
Bump.
http://www.ebay.co.uk/itm/LT1083CP-L...gAAOSwnFZXUVNy
I use one of these with a Noratel FE050/12 12V transformer.
A swapped to a bigger heatsink so it runs luke warm. good psu, even better when you use it a s apre-reg running into one of the these.
http://www.ldovr.com/product-p/tps7a4700-lm31x.htm
As good a 1amp psu as you can get anywhere, all in for about £65.
Hi
I have 2 15VDC supplies that may be of use to you.
The first is the best and well regulated. It's new and unused. They cost £100 with duty and VAT and I want £55 including postage. Mine is the 15VDC 2A version but details can be seen here https://www.ebay.co.uk/itm/NEW-25W-T...kAAOSwAPlXgK5G
The second is regulated but not as well and only 1A. Has an upgraded Talema transformer and I want £35 for this. Details here with the inferior transformer https://www.ebay.com/itm/13103441505...c=1&rmvSB=true
Happy to send photos of both inside and out.
