Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 75
Thread: new cartridge on its way .
  1. #31
    I'm glad that your liking your Black. The only down side now is if your tonearm and head-shell combo get the best from the cart.
    PRE
  2. #32
    Bigman80 Guest
    no comment
  3. #33
    I'm Tim.
    I like the ortofon Cartridges
    They do a lot that is right to my ears.
    I bet your black is a bit fab.
  4. #34
    I'm jamie.
    the alphason is doing sterling service at the moment
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
  5. #35
    Nothing wrong with that Tonearm it’s beat a few much more expensive tonearms that I have had
  6. #36
    I'm Robert.
    i'll sort some out tomorrow as it was a bit of a rushed job to get it on and have a listen,the proper set up i will do at the weekend.
    im surprised how small it is in real life.
    wanna buy a decca ??
    Ha Ha, Now that was exactly my thought when I got mine - amazing.
    Glad you're enjoying it.
    If it's brand new it'll change subtly over time as these things do, for the better too I'm led to believe and again it's subtle.
    Mine had low hours so I dont think I have had that to worry about, although it did look brand new when I got it
    Keep us posted
    My System:
    CDP - Pioneer PD-91
  7. #37
    montesquieu Guest
    Default new cartridge on its way .
    Quote Originally Posted by stevied View Post
    Should be fab with the Alphason. I might be tempted to put 2-3g headshell weight in the mix just to get it digging a little deeper.
    I really rated my Ortofon Jubilee (cadenza black’s predecessor at top of the kontrapunkt/cadenza line. ) The description above is spot on.
    I can still join the Ortofon club I still have an SPU Royal and a vintage alnico SPU GE in use daily.
  8. #38
    I'm Russell.
    So next week we can expect some listening impressions?
  9. #39
    I'm jamie.
    Sooner than that!
    My System
    John Wood KT88 Amp.
  10. #40
    for some reason i thought you had a micro seiki tonearm bolted to your vinyl grinder! My eyesight must be going.
    PRE
