Page 10 of 13 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 123
Thread: Denon 103r - is it worth the aggro?
  1. #91
    I'm Kevin.
    It will (if you enjoy that type of presentation). However, it's essentially no longer a DL-103... Also, it'll no longer need as much mass to perform optimally, as the compliance will have been altered, so if I were you I'd try backing off the mass a little (by using a lighter headshell weight) and see how it sounds then. You may prefer it
    I find the comment about it no longer being a DL-103 mildly amusing coming from the master of modifications.
    When using the modified DL-103 there is no additional headshell weight. It weighs over 20g so backing the weight off is not possible.
    Kevin
  2. #92
    Lol, yes, but have you ever seen me using a modified 103?
    Ok, so the added mass has been built into the cartridge itself, fair enough. Have you tried adding the same level of mass to your C1? If not, it'll defo benefit from it
  3. #93
    I'm Kevin.
    Pretty much the same mass. The additional mass was made specifically to run a DL-103 on the Funk arm.
    Kevin
  4. #94
    H'okay dokes
  5. #95
    Post #59 'The Gen on DL-103s' has been tidied up a little, with some new info added, for anyone interested
  6. #96
    Bigman80 Guest
    Ok, the first thing you should know, in relation to DL-103s, is that since Denon stopped trading as Nippon Columbia [later Denon Ltd] in 2002, and merged with Marantz Japan INC, the core design of the 103 changed [moving from using Alnico to rare-earth magnets in the generator], carried out in order to save costs and maintain the current relatively low selling price, for what is a high-quality MC cartridge.
    The only reason the currently produced models sell for what they do (and those before it), rather than five times the amount, which would be more realistic considering the performance on offer, is because of economies of scale, due to Denon being a HUGE Japanese corporation. Therefore, you simply cannot judge this cartridge on its retail price alone.
    It's 'cheap' because of the above, and because more than ten thousand of them have been produced since it was first introduced in 1958, mainly for radio stations and broadcasting studios throughout the world, but mostly in Japan, for the NHK - the Japanese equivalent of the BBC, so they needed to be in plentiful supply when replacements were required.
    If it hadn't been for the above, and if the same cartridge had been produced by a 'high-end' cartridge manufacturer, with a desirable 'badge' amongst audiophiles, and housed in a quality aluminium body, it would've sold for at least £1k, perhaps more. Therefore, it has to be used and judged in that context. One of the biggest mistakes people make is thinking of it as a 'budget' £200 cartridge (due to its price tag), and so a) not treating it seriously, and b) not spending enough on partnering ancillaries, especially tonearm and phono stage.
    This is a cartridge that really needs to be treated seriously and used in a certain way, in order to get the most from it, and to hear what all the fuss is about, in terms of its reputation and cult status amongst vinyl aficionados worldwide - and the sonic rewards obtained by partnering it correctly are significant. I'll get to how best to achieve that shortly.
    Ok, let's go back to how the design of the 103 was changed in the early 2000s, and Denon then abandoning their use of Alnico magnets, in favour of a less expensive variety of rare-earth magnets... There are those that would say a 'magnet is a magnet', and so as long as it performs its primary function, it shouldn't matter which one is used. When it comes to things like cartridges and loudspeakers, however, I'd beg to differ.
    However, I'll leave the technical folks (and anyone else interested) to debate that one, but what others and I who've been using DL-103s (of various forms), for the last 30-odd years can clearly hear, is a marked difference in sound between ones produced pre-2002 (using Alnicos), and post-2002, minus such. I can go into that in more detail for anyone who's interested, but trust me, the difference (musically) isn't subtle!
    Therefore, what this essentially means is that unless you've actively sought to obtain a NOS (or good condition 2nd hand one), from the 'golden era', then the 103 you're listening to now isn't the 'real McCoy'...
    And that's one of the reasons why, when buying a DL-103 it pays to check the serial number, because sometimes old stock items, lying forgotten in warehouses somewhere, can often show up for sale on the likes of ebay - AND also one of the reasons why limited edition ones sound best, simply because they were produced during the 'Alnico era'. The other important reason is because they all featured the use of improved, high-quality body-shells.
    Therefore, it is the plastic shell, used on all entry-level 103s, that is *the* single most limiting factor, in terms sonic performance. Not the stylus*, tip, suspension or anything else [*only when in certain circumstances Denon chose to fit elliptical styli]. Denon themselves knew this (as that's where costs had been cut to keep the price down), which is why they addressed that issue in the design of their limited edition cartridges.
    What they didn't do with those models was fit 'fancy tips' [fine-line styli], which yes in some areas improves matters (namely ultimate detail retrieval and lower distortion), if you go for one of the many 'tarted up' versions for sale, but also subsequently (and fundamentally) changes the sound, resulting in, as some have noted already, losing the 'soul' and inherent musical abilities of the cartridge in the process, and what makes it special.
    If you're the type of listener who tunes into [and gets excited about] twinkling 'airy highs' and filigree detailing, and prefer cartridges with those traits, along with a lighter, brighter sound [count me out, which is why I haven't done it], then by all means fit a 'fancy stylus', FG or whatever, to a 103. But in doing so realise that you'll have lost some of the soul, bass authority and 'boogie factor' with it, as the tone (and musical nature) of the cartridge changes fundamentally, when the original stylus is replaced for something 'better'.
    That's the trade-off, which always exists in some form with audio. It largely depends, however, on how you assess sound in a hi-fi context, and also what type of music you listen to mostly, as to whether or not you'll fall in love with a 'pimped 103'.
    The sensible money (and considerable experience) says that retaining all else but the plastic body-shell (and perhaps upgrading the internal wiring to LC-OFC), along with the stock shell, to something less resonant, is the way to go. That's why Denon did precisely that with the DL-103SA, and others before it. Now which type of shell you choose is the fun part! Because there are so many options...
    Just bear in mind that there are fundamental sonic differences between wood and metal, and then from one type of wood and metal to another!! So experimenting and listening is the only way to discover what's best for you, although in that respect I can provide some basic pointers.
    So to sum things up for Oliver, and any other potential buyers of a DL-103... If you want to hear what one is truly capable of, then it *must* be NOS, pre-2002, and preferably either an M, SA (introduced after 2002, but uses generators from old stock), GL or C1. There are some other good ones too, such as the D and FL, but they sound quite different.
    Plus, there is the truly superb DL-S1, and 'giant-killer' supreme (my main and favourite cartridge) but that's a rather different beast! And now unfortunately discontinued. Also, forget about hearing any of the above cartridges properly unless you have the following items in place to use them with:
    1) A high-quality D/D turntable (SL-1200, SP10, Pioneer PL-71, or any of Pioneer's, Denon's, Toshiba's or Sony's best efforts from the 70s). Or with something truly amazing, as shown here, such as a Trio (Kenwood) L-07D):
    2) A high-quality high-mass detachable headshell tonearm (such as those from the likes of Fidelity Research, Ortofon and Audio Technica, or Jelco).
    3) Or a medium-mass 'lossy' tonearm, such as Denon's own and from other Jap manufacturers, or the likes of a NOS Linn LVV), fitted with a high-mass headshell (preferably constructed from magnesium). The high-mass bit is crucial (the magnesium bit less so, but definitely better), and in terms of mass, I'm talking minimum 18g for the headshell alone!
    4) A top-notch valve MM phono stage.
    5) A top-notch moving-coil head amplifier (or SUT), which loads the cartridge correctly and provides sufficient gain. However, in my experience 103s work best actively, with head amps. The Denon HA-500 is a good choice, and at the other end of the pricing scale, the popular little Lentek unit, or the likes of a Rothwell Headspace.
    And last, but certainly not least, set the cartrdge up with forensic attention to detail, in terms of optimising VTA, azimuth and VTF (downforce) - and there, always aim for the higher end of the recommended user range. Also, always use non-magnetic stainless steel allen bolts, to secure the cartridge to the headshell, nipped up tightly, and good quality lead wire. The thin wires you get 'free' with basic headshells are crap, and act as a significant bottleneck.
    If you can't put all (or most) of the above in place, then FORGET all about hearing any DL-103 properly!!
    Bloody hell, it's lunchtime now.... Anyway, hopefully all this will be useful info.
    That Kenwood is a stunner. I'm building a MM Valve phonostage in direct reference to this thread. Boards ordered for the PSU and Phonostage. It's going to take some time due to my incredibly low experience but it will be made with one eye on putting a "Giant Killer" through it.
  7. #97
    I'm Robert.
    Yes indeed - The Kenwood / Trio is a classic, almost over engineered but in the positive sense
    My System:
    CDP - Pioneer PD-91
  8. #98
    Sounds like a good plan, Oliver. Remember also to factor in a quality head amp. Don't rush it, do things right, then strap an 'SA' or 'GL' onto your AT arm, with a top-notch high-mass headshell, and you'll be utterly gobsmacked at the sound (and sorted for life for vinyl replay) - or at least until you wear out the needle!
    The Kenwood, and likes of Pioneer Exclusive P3 (shown below with its 'clothes' off), or EMT 950, represent the pinnacle of T/T engineering, and precisely how turntables should be built (if achieving faithfulness to what's contained in the grooves is the goal), and only rivalled today, IMO, by the Continuum Calibrun, at significantly more money (!) - and I know which I'd rather have!
    Pure engineering excellence, making most belt-driven turntables sound like toys. It's what we should've all been using, back in the day, instead of dicking about with rubber bands!!!
  9. #99
    Bigman80 Guest
    Sounds like a good plan, Oliver. Remember also to factor in a quality head amp. Don't rush it, do things right, then strap an 'SA' or 'GL' onto your AT arm, with a top-notch high-mass headshell, and you'll be utterly gobsmacked at the sound, and sorted for life for vinyl replay!
    We'll see how it goes lol. It's going to take some time !!!!!
  10. #100
    The best things in life are always worth waiting for, mate
