Results 1 to 10 of 17
Thread: Help I think I've screwed up
    I'm Neil.
    Default Help I think I've screwed up
    Looking for some help from you more experienced folk on th forum.
    I built a couple of subs over the weekend, they sounded very good, I tried different placement and in doing so accidently managed to touch two banana plugs together whilst everything was up and running. The banana plugs sparked and now the amp I was powering em with sounds like crap.
    It does power up and I can get sound from it but it sounds terrible. The amp is a Crown xls 1000.
    Have I screwed something up guy's?
    Neil
    I'm Neil.
    yes.
    Regards Neil
    RothwellAudio Guest
    Quite possibly, yes. Some amps will survive a short circuit at the output - some won't. You may have DC on the output too, so I wouldn't connect them to any speakers. Check for DC on the output and if there is any (more than about 100mV) there's definitely a serious fault. Even without DC it sounds like the amps will needs repairing.
    you might get lucky and it is fused but otherwise its in need of the doctor
    Hi Neil, when are you coming round?
    Give me a bell mate
    I'm Neil.
    Thumbs up
    Thanks all whatever's happened it doesn't sound good at all!!
    Alan thanks buddy will give you a bell a bit later mate we're out shopping at the mo
    Crown amps are built like Soviet tractors, so it might just be a fuse. Check before plugging into any speaker.
    I'm Deleted.
    If it's a fuse how does it sound like anything?
    Account Deleted
    I have had amps sounding 'garbled' with a blown fuse.
    I'm Rob.
    It appears there is a reset button on the rear of these amps? Not sure if that would help. These are Class D amps and some Class D chips are not happy when you short the speaker outs. There is a Crown Manufacturers vid on YT about a factory reset, looks like you have to connect it to a laptop.
    https://youtu.be/ZCBe7-6rw4M
