Results 1 to 10 of 10
Thread: Salesmen
    I'm Adrian.
    Default Salesmen
    I recently put down a payment on a second hand valve amp, advertised as less than 350 hours use on the valves. As I'm on the point of completing payment I asked for confirmation that all was as it should be - and was told I'd need new valves as the originals had been used hard. I don't get why people can't just be honest at the outset. The amp.is less than 5 years old so other than buggered valves should be okay in other respects... I'm hoping.
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
    Used hard? Depends on the amp as to whether the valves are used hard.
    What amp and valves is it Adrian?
    I'm Adrian.
    ARC ref 75, kt120's. Sorry just checked
    email again - 'well used'. I don't mind that - but it's miles apart from 350 hours lol
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    I'm Paul.
    The ARC KT120s should be good for 5000 hours so if knackered after 350 hours this would mean it has had the b0ll0cks thrashed out of it, like a used Fiesta XR2. I’m not saying this is case, just that something doesn’t seem to add up with the guys storey. ARC stuff tends to be battleship build quality, so other than the valves the rest of it should be solid.
    ~Paul~
    Quote Originally Posted by Primalsea View Post
    The ARC KT120s should be good for 5000 hours so if knackered after 350 hours this would mean it has had the b0ll0cks thrashed out of it, like a used Fiesta XR2. .
    Just interested to know how one can thrash a valve in a known good circuit.
    I'm Neil.
    If lying about the valves, what else are they lying about. My advice, avoid.
    Regards Neil
    System 1 (Living Room) : AMG Giro turntable, AMG 9W2 tonearm, Air Tight PC3 cartridge, Passlabs Xono phonostage, AMG Reference armcable. Marantz CD7 CD player, Sony HAP Z1es Digital File Player + Audioquest Jitter Bug, AMR DP777 DAC + HP laptop + iFi Audio i power, Wireworld Starlight USB + Audioquest Jitter Bug, for computer audio, Audio Valve RKV2 headphone amp, headphones Grado GS 1000, Nakamichi CR5e tape deck, Balanced Audio Technology VK300se integrated amplifier, Anthony Gallo Reference 3.1 speakers. Cabling: Signal - Atlas Mavros, Audience AU24, Speaker - Atlas Mavros. Mains Cabling: Audience AU24, Analysis Plus, TCI. Mark Grant distribution blocks, Equipment tables Target Audio B series.
    System 2 (Music Room) : Loricraft Garrard 401 turntable + SME 5 tonearm + VDH MC10 cartridge + Graham IC70 tonearm cable, Modified Technics 1200 turntable + Triplannar 7 tonearm + VDH Frog Gold cartridge + Paul Hynes SR7 PSU, SME Model 20 turntable + Graham Phantom tonearm + Ortofon MC5200 cartridge + Graham IC70 tonearm cable, Balanced Audio Technology VK10se phonostage, Moon Andromeda CD player, Esoteric P5 SACD transport and P 5 DAC, Toshiba 9500 DVD Audio player, AMR DP777 DAC + Dell Laptop + iFi Audio i power + JKenny JKSPIDIF + Wireworld Starlight USB - for computer audio, Kenwood 8300 tuner, Revox B760 tuner, Magnum Dynalab signal sleuth, Leak Troughline tuner + EAR Stereo decoder, Revox B77 mk 2 & Revox A77 mk3 reel to reel recorders, Balanced Audio Technology VK52se pre-amplifier, Music Reference RM200 mk1 power-amplifier, Anthony Gallo Reference 3.5 speakers. Cabling: Signal/Speaker - Audience AU24, XLO Type6. Mains Cabling: Audience AU24, TCI. Mains distribution blocks Mark Grant and Russ Andrews, Equipment tables Clear Light Audio.
    I'm Paul.
    If it has been used a PA Levels continuously, especially if used with fairly reactive or low ohm speakers. Also the bias on thes amps can be adjusted by the user via little holes in the front plate. Sometimes people have strange ideas and set the bias current far too high. Or if you are John Cleese you can beat them with a leafy branch.
    ~Paul~
    I'm Shaun.
    Surely if any valve amplifier runs its valves at close to their operating limit they are never going to last very long independent of whether it is at high volume or not...?
    MARANTZ CD6005 INTO AUDIOLAB M-DAC - PRIMA LUNA PROLOGUE THREE PREAMP - PRIMA LUNA DIALOGUE PREMIUM POWER AMP - SPENDOR S3/5R2 LOUDSPEAKERS - ATLAS HYPER INTERCONNECTS - TELLURIUM Q BLUE LOUDSPEAKER CABLES - ATACAMA STANDS - PRO-JECT SUPPORT PLINTH
    I'm Shaun.
    Yeah, that's kind of what I meant
    I'm I'mteachingmarcotheartofpishanto.
    Quote Originally Posted by farflungstar View Post
    Knock them hard on the purchase price for a full overhaul
    Music , fills the gaps between silence !
    TAT Sale post Leader " Marcos Mentor "
    Also a pishanto specialist confirmed by Head Daftee
    Real name " Allen " or "Zoomer Nut”, “Numpty Napper”.
    ±± KEEP IT REEL
