Results 1 to 10 of 10
Thread: Amplifier with dac & remote
    I'm Carlos.
    Default Amplifier with dac & remote
    I just sold my Naim Unitiqute as I was not happy with the sound quality. I currently have a Nait 2 which I much prefer however I am looking for an amplifier with dac and remote control to replace the Unitiqute.
    Not only it must sound good but I also take aesthetics in consideration so no massive jap amps (I also have one of those).
    What are the options? Amplifier with dac or should I just go for a dac with remote + the Nait 2?
    I'm Shane.
    What exactly didn't you like from Unitiqute's performance ?
    S.
    I'm Carlos.
    Quote Originally Posted by southall-1998 View Post
    S.
    I did not think it matched the Nait 2.
    In my opinion the Nait 2 injects more life into music especially a low volume which is how I listen most of the times.
    The UQ also needs to be pushed hard to make my Usher S520 sing.
    What is your budget ?
    Primare I32 with MM30 dac/streaming board.
    There's one here:
    https://www.ebay.co.uk/itm/Primare-i...sAAOSwIFtaALQU
    (Nothing to do with me ! Just so you can see what it does.)
    I'm Carlos.
    Budget is £1000
    I'm Paul.
    The Rega Dac R is well within your budget. Solid DAC as well but ultimately that depends on your particular taste.
    ~Paul~
    Quote Originally Posted by Conan View Post
    I also preferred the Nait (+ Sonos in my case) to the UQ, which I was underwhelmed by.
    Eventually, I moved on from Naim and I now use a Peachtree decco, which I picked up for £350.
    The Quad Vena would also tick all your boxes.
    I'm Mark.
    I've been researching this too and come across the Marantz HD-AMP1. All the reviews are very positive and its not a big box either.
    Stereo
    Amp: Temple Audio Monoblocks c/w Supercharger PSU
    Source: Sonos Connect
    DAC: Bushmaster MK2
    Speakers: Elac BS263
    Speaker Cable: QED Ruby Anniversary EVO
    Turntable: AT LPW50
    AV
    Amp: Yamaha RX-A1050
    Source: Panasonic UB820
    Speakers: Quad Lite 2
    Sub: BK XXLS 400
    I'm Simon.
    If you really like the NAIT 2, then using a DAC with that seems to make the most sense.
    However, you might also like to look at a Heed Obelisk Si with DAC card.
    If you're prepared to broaden horizons a bit, then a Bel Canto C5i is a great little amp and DAC. Quite different from a NAIT, but you may well like it.
    Lindemann Network Bridge > McIntosh MHA150 > Shahinian Larc speakers
