Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Oliver's new interconnects
    I'm Brian.
    Default Oliver's new interconnects
    I've had Olivers new interconnects in my system for the last few days and I'm posting my thoughts on them here . Firstly ,these interconnects were used in my system which contains a Goldring GL75 turntable , Firebottle OTP phono stage , a Korus music server / DAC3 French DAC , Croft pre and power amps , and a pair of Tannoy 637 speakers . I've had this system for quite a while now and I'm very familiar with its SQ . These interconnects will probably sound different in another system . I think Oliver would like them tried in a few different systems to gain as broad a spectrum of opinions as possible .
    I know Oliver isn't really interested in feedback regarding build quality , but I must say that these interconnects are beautifully built and a credit to his skills as a cable maker .
    Once plugged in between the DAC and amps the first thing I noticed was the sheer power which these interconnects conveyed . Initial impressions were that there was plenty of everything . Top end was smooth and detailed , the midrange , particularly voices , was very nice indeed , and bass was deep and tuneful . The timbre of instruments was very well conveyed and voices had a very nice , warm , texture to them . Drums also sounded like they should . I was also surprised at how high I could turn the volume without experiencing and harshness . These are indeed very smooth , yet powerful , sounding cables with a big soundstage and good back to front imaging .
    I experienced the same sort of effect when using the turntable . There was plenty of detail from a relatively inexpensive Nagaoka MP110 MM cartridge and I'm pretty sure that excellent results will be obtained from a more expensive MM or MC cartridge .
    One small caveat for me was that there was a very slight loss of '' airiness '' , however I'm pretty sure that this is more a symptom of my system rather than a problem with Olivers interconnects .
    If your system sounds a bit bright , harsh , or lacking in detail , then I'm sure these interconnects would be an excellent choice . They're certainly well worth a listen IMO and Oliver is a very friendly helpful guy to deal with
    Now posted to Jamie . I hope he enjoys them as much as I did
    Regards
    Brian
    Korus Computer Audio music server .
    DAC 3 French DAC
    Amplifier : Rega Brio R
    Speakers : Tannoy 637
    Speaker cables : Chord Epic Twin
    I'm Brian.
    Can a mod fix the title please . It should read '' Olivers new interconnects ''
    Thanks .
    Regards
    Brian
    DAC 3 French DAC
    Done!
    I'm Brian.
    Thanks Geoff , you're a gent
    Regards
    Brian
    DAC 3 French DAC
    I'm Mark.
    Though it should really be Oliver’s .
    100% Analogue
    I'm Brian.
    Thanks Mark
    Regards
    Brian
    DAC 3 French DAC
    you insinuating
    glad u enjoyed em/ call them son of brian cables
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/M55E/EMOTIVA XPS1 - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER23, DEEZER HiFi - ECHO DOT - SMSL M6 MINIDAC - RPI/AUDIOPHONICS - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
    I'm Brian.
    Nah mate . These interconnects stand on their own merit
    Regards
    Brian
    DAC 3 French DAC
    Moved to Strokes of Genius, as it's essentially a review. Also, as somewhat of a pedant, I've added the required apostrophe to the thread title!
    http://www.thestainedglasscompany.com
    "A man is a success if he gets up in the morning and gets to bed at night, and in between he does what he wants to do" -- Milan Kundera.
    I'm Brian.
    Thanks Marco , appreciate the help
    Regards
    Brian
    DAC 3 French DAC
