As it no longer has the lip on the platter due to the brass sheet on top, does one just use the standard 5mm achromat on the new sl1200g?
My System:
Turntable - Linn Sondek LP12, Kore, Lingo 4, Roksan NIMA, Lyra Delos Cartridge, Roksan HDC-03 arm lead, Trampolin 2 base, Tiger Paw Vulcan, Denon DCD-A110 Cd player, Tag Mclaren DAC20 Digital to Analogue Converter, SPM Interconnects, Nordost Red Dawn Leif Speaker cable, Spendor S3/5R2 Target R1 speaker Stands, Atacama ECO 60/40 hifi racks, Sennheiser HD565 Ovation headphones
Is there a rubber mat on the new version?
If do, the easiest thing to do is get the Achromat of the same thickness.
Kevin
If you really want to get the best from your new beauty, speak to guy at Puresound and get a Tenuto Platter mat. I will never part with mine.
I presume the 1210 can handle the weight?
Analogue studio crystal mat at £90 or less. It's what I use on my techie and it has disposed MANY mats over the years.
This is the best mat i’ve ever used on my Techie
http://www.fonolab.com/obchod.html?product=1059
and not ridiculously expensive!
If there isn't a lip on the platter then the standard Achromat should do just fine. Although the Achromat SL1200 version would do just as well so don't be too concerned. They are also available in several different colours in the 3mm version if you so fancy. I personally would go with the 5mm version.
Sent by me using an appendage
SME Model 15/V tonearm, Lyra Dorian, EAR Phono Box.
Luxman 509X amp.
PMC 25 23i speakers.
Innuos/Roon/Qobuz/I-Pad. Oppo UDP-205.
Cables by Kimber, Yannis and Audioquest.
Audioquest Niagara. Tube Distinctions Mains power filter. Project RCM. Zerostat.
Lol... I see that Andrew's getting all sorts of different recommendations for mats. Much depends on how 'serious' he wants to get into the whole thing, as it can be a bit of minefield.
My recommendation for him to use an Achromat was simply to keep things simple (as he wants to keep the T/T stock), and not spend a fortune, as well as being effective - and the Achromat ticks all those boxes.
If you do go for one, Andrew, buy the 5mm version, as sounds much better
Yep 5mm is the way forward with the achromat I had one of these as well I think there may be a special technics 1210 version, best to check just in case.
Thanks Marco, and everyone.
As you said, I want to keep it as stock as possible.
Would I just be better geting the standard 5mm version now rather than the more expensive Technics version as it now has no lip?
I must say, i think i prefer the look of the old mat rather than the new one, i suppose it could grow on me?
I suppose this the mkII variant.
My System:
i never bothered with the special 1210 version. Simple 5mm version works very well.You might be able to pick one up cheaply. Ask on the forum.
