Results 21 to 30 of 33
Thread: Bright Star Isonodes / Coupling vs. Decoupling
  1. #21
    Not directly onto carpet. Any residual moisture in the slabs will rot the carpet. It happened to me! There's always some moisture retained by slabs, even if they look dry.
    Shit, its complicated.
  2. #22
    I'm Neil.
    Default Bright Star Isonodes / Coupling vs. Decoupling
    Just use a few discs of paper under the domes if you don’t want marks on the carpet. No need for additional platforms.
  3. #23
    Isonodes here, can't hear a bit of difference, doesn't surprise me.
  4. #24
    I'm Neil.
    So you are still getting room boom? Seems like you will need to use some DSP / EQ to sort your issues then I’m afraid.
  5. #25
    I'm Phil.
    some great ideas in this thread , just posted a similar one on the wam to see what alternatives to blu tac
    https://hifiwigwam.com/forum/topic/1...veneer/?page=2
    some more info on the iso puck which looks interesting
    https://youtu.be/aojtGHVga-Y
    Eric Bibb
  6. #26
    Yes, still as boomy as ever. Gonna try an amp change soon anyway. But I do need to do some room measurements.
  7. #27
    I'm Neil.
    Amp won’t help you. It has to be a room mode if it’s not the floor, or just boomy speakers. I think the former though.
  8. #28
    I'm Russell.
    What kind of speakers are you working with? Room size? Just curious...
  9. #29
    I'm Phil.
    got some isopucks in situ under my b&w standmounts . rather like these little babies . cost effective upgrade . immediately noticeable improvement in soundstage and full bloodied sound . worth the money
    http://www.isoacoustics.com/isoacous...ovember-issue/
    Eric Bibb
  10. #30
    I'm Neil.
    Quote Originally Posted by hifinutt View Post
    Good stuff. Did you place them under the speaker stands or the speakers themselves?
