For sale: Apogee Centaurus Minor Hybrid Ribbon speakers
Simply superb Hybrid Ribbon speaker for sale. Lots about this design on the web. Have had three of these now, all have been great but this one's been the best by a long way. A lot of that is down to the bass drivers which are original and in excellent order, as are the ribbons (not too difficult to replace if ever needed in the future). Same one's used in the Apogee Stage. Very few signs of wear, a little crush on the base/rear of one, tiny bit of lift on the veneer on top of one (should stick down fine). Sound quality? Gobsmackingly good within the hot spot. Loves valve amps. Demo a pleasure. Collect only from Bedford. £350 (there's an identical pair on sale at a well-known used dealer for £650!).
Specifications
1991-1994
Height 100 cm
Width 35 cm
Impedance 4-6 ohms
Bass driver
6½” Dynamic cone woofer
Midrange/Tweeter
26″ Aluminium/Kapton ribbon (etched 6 segment)
Max Sound Level
107 dB @ 4 meters with a 50 W amplifier
Frequency response
(-3dB @ 40Hz) to 20kHz
Crossover frequency (electronic)
800Hz
Suggested amp power
50W (into 8 ohms) 100W (into 4 ohms)
Weight
24kg/52lbs each
Finishes available
Silver grey
DSC_0440 by Brer Rabbit, on Flickr
DSC_0439 by Brer Rabbit, on Flickr
DSC_0442 by Brer Rabbit, on Flickr
DSC_0441 by Brer Rabbit, on Flickr
DSC_0449 by Brer Rabbit, on Flickr
DSC_0445 by Brer Rabbit, on Flickr
DSC_0444 by Brer Rabbit, on Flickr
Indeed. Love to hear how well these perform. I think they look great without the covers on.
Replacement new ribbons for these are available.
Thanks for the kind comments folks. One tries
And yes, they sound as good as they look!
Ah well, gave it a go here. Now on Ebay...
Originally Posted by
Lawrence001
On ebay?
Yup...
- You may not post replies
- You may not edit your posts
Forum Rules
