Slav, you're giving the output of your carts at 5cm/s, it's more usual to give the 3.5cm/s measurement, which is closer to .5mV. The Paradise has enough headroom on the input stage to take 1.0mV of input from the cartridge. Standard gain is 64db. You'll have no issue with input level to the Paradise, or clipping on output.
Are you just interested in working out the numbers for the sake of it, or do you actually have too much level for your pre-amp input?
Reducing gain to trim noise from the Paradise is a pointless exercise, there is virtually no noise, and you just lose a touch of dynamics as you throw out the gain. This ain't a valve stage.
