Cart Loading MC
This is a 50/50 topic (diy bent).
Assume you're buying a fancy new phonostage, what would you expect for MC loading options? Are you happy swapping resistors in siL sockets, do you expect DIP switches or do you want to see some multi-position mil-spec switched attenuator type arrangement?
What's the best you've owned and used?
Pics if possible please... ;-)
