Results 1 to 5 of 5
Thread: Quad's
    I'm Dan.
    Default Quad's
    Hi Guys
    33/303
    Just looking to buy a separate lead so i can run a different pre to the power and have realized that i have been using 4 pin connectors between the Pre & power getting a little bit of hiss at the mo doesn't change with volume? Disc & Tape Boards Maybe? all new power leads and 4 pin to 4 pin so i cant see why its doing it...
    Thank you
    Technics 909 U & S Pre & Power Amps & Tannoy eclipse Speakers & Cambridge Interconnects & QED Speaker Cable , Marantz CD 67 OSE , Technics ST GT 1000 Tuner
    Vinyl :
    Rega Planar 2 / RB250 / Ortofon OM Super 10 / VDH Oil Bearing Upgrade / Roksan R Mat
    Vintage Second System:
    Sony TA 88 Amplifier , Sony ST 88 Tuner , Realistic Minimus 7 Speakers , Technics SL PG400 CD player , Rega P2 - AT110E Cartridge
    What type of connectors are used on the preamp you wish to use? If they are RCA 'phono', then a suitable lead terminated with these at one end and 4-pin DIN plug at the other end is readily available from Flashback Sales.
    Have you listened to this month's choice in the Album Club?
    I'm Dan.
    Hi Barry
    I only need a 4 pin to RCA from the 303, Just wondering this as i have a hiss problem at the mo just wondering if its because im using both 4 pin to power & Pre if this makes sense?
    Vinyl :
    If you are using a 4-pin DIN to 4-pin DIN lead between your 33 and 303, then you shouldn't be having any hum or hiss problems. Is the hiss noticeable at low levels?
    I'll have a look in my collection of interconnects to see if I have a spare RCA to 4-pin DIN lead. I'm not at home at the moment, so it won't be until the middle of next week until I can have a look.
    I'm Dan.
    Hi
    Yep the usual 4 pin leads between pre & power - the hiss is their doesn't change in volume its just their which is odd never had problem before was always silent been reading it could be the boards shall i take them out clean them and put them back in? Sure im willing to pay for a 4 pin to RCA if you have one no rush im just using the Quads again as sat in the box for a while...
    Thanks
    Daniel
    Vinyl :
