Thanks Shane. Not sure I will even use a lid just now. The cabinet is a bit of a tight fit, and I aim to put the TT2 on some sort of more solid support, making even less room in there. For now I just use a silk handkerchief to keep the dust off. Works fine. OTOH, if we ever replace the cabinet with a different stand, then a lid would be great to have. Thanks for the tip!
Svend
