Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 108
Thread: New to streaming, please help.
  1. #21
    I'm Edward.
    The bitrate for Prime Music is 320kbps MP3 is this any good ?
    Amazon streams at up to 256k AAC which generally is better than 320k MP3. For comparison Spotify streams at 320k OGG. All of it will sound 'good' - and will be enhanced with a decent DAC.
    Source: Win10 server, Win10 Mini-ITX Renderer running JRiver & Tidal/Roon
    DAC / Preamp: Perreaux DP32, Secondary DAC:
    Chevron Paradox
    Amp: Radford Revival STA25, TubeHunter Class D IRS2092
    Speakers:, Tannoy Eatons, Kudos Cardea C2, BatPure Supertweeters, Acoustic Research 8BX (modded)
    Power Conditioner: ISOtek Qube 1kw
    Currently resting: Radford Revival Prototype preamp, Paul Baldwin 405C amp, PMC LB1 Signature
  2. #22
    Be fine, I listen to a few radio streams that only give 128 and some are outstanding, if you want a listen to a really good 128kbps stream try Space Station Soma ( Electronic ) or at 192kbps try Blues Radio Athens to show what lower bitrates can do.
    I don't know why they sound better than other streams at the same bitrate but they do.
  3. #23
    I'm rupert.
    It's all he needs and on budget. He has a laptop. It's a very good dac
    sorry Grant, a laptop - even a Mac - is a crappy DAC.
  4. #24
    I beg to differ and a few in here will agree with me it's a very good dac
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/M55 SAS/EMOTIVA XPS1 - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER23, DEEZER HiFi - ECHO DOT - SMSL M6 MINIDAC - RPI/AUDIOPHONICS - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
  5. #25
    I'm rupert.
    I guess it depends to what you compare it to
  6. #26
    I'm AMusicFanNotAnAudiophile.
    In truth the DACs in most laptops are more than up to the job in hand.
    Where things fall down is in a couple of areas.
    The analogue output stage can usually be bettered, and on top of that you're likely have some switching noise contamination over the audio circuitry. It will be very low in amplitude, but it will be there.
    Irrespective of all of this, a laptop hooked up to an amplifier is a decent enough way to get to grips with streaming.
    Chris
    Once we've made sense of our world, we wanna go fuck up everybody else's because his or her truth doesn't match mine. But this is the problem. Truth is individual calculation. Which means because we all have different perspectives, there isn't one singular truth, is there?
  7. #27
    I'm Edward.
    ^^^ ditto ^^^
    And, assuming one has a laptop or old computer, it is effectively free to dip one's toes into the streaming world. Well perhaps only for some cables costing a few quid.
    Chevron Paradox
  8. #28
    I was suggesting putting a dac inbetween both. Stream with laptop to dac. 100 or so and your there as he has a lappy and amp. Spotify sounds fine this way and was what the guy asked for
    Grant ....
  9. #29
    I'm Neil.
    Just bear in mind that streaming from Spotify, TIDAL etc. means that certain tracks (like from Universal Music Group) will be watermarked, which *can* be audible. Sometimes you'll notice subtle distortions from streaming that you don't notice on CD. Thus, don't tear your hair out thinking there's something up with your system if you hear it!
    Mana Acoustics Racks / Bright Star IsoNodes Decoupling >> Custom Silent Media Server >> Halide Bridge USB (with AQVOX USB power) >> Pedja Rogic's Audial Model S DAC + Pioneer PL-71 turntable / Vista Audio phono-1 mk II / Denon PCL-5 headshell / Reson Reca >> LFD DLS >> LFD PA2M (SE) >> Royd RR3s.
  10. #30
    Currently play just vinyl and CD. Want to try streaming, that is downloading music from the internet! I have a laptop, but no idea how to go about all this. Do I need a streamer? My amp is naim 72, so pre digital, so guess I'll need a dac?! Was thinking about getting a Sony 700 or similar, do these have dacs? So with these 2 amps in mind, how do I go about this? Sorry for my complete ignorance........... Budget? Well, normally buy second hand, so I guess 100 - 300. Ta.
    Mike,
    If you are still searching for a solution I have two items which might meet your needs.
    The first is a Musical Fidelity V-Dac https://www.whathifi.com/musical-fidelity/v-dac/review
    The second is an HRT Music Streamer II https://www.whathifi.com/hrt/music-streamer-ii/review
    Both are simple in use and plug into your PC usb port at one end and your amplifiers rca input at the other end. Both devices are in excellent condition and would be well within your budget. PM if you are interested in either.
    Geoff
