Page 13 of 20 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 200
Thread: New to streaming, please help.
  1. #121
    Bollocks, I don't think I can connect the N-50-K to Spotify. I set it up, Ethernet cable, and analogue cable to amp, set up Spotify apps on phone and laptop, but it cannot find device. Looking on internet it seems these older N-50 weren't compatible with Spotify, **** it. Internet radio works ok. Looks like this was complete waste of time.
  2. #122
    oops.. that's a bugger. could try a chromecast audio... they are about £30... work pretty good.
    I'm Edward.
    When I looked at the spec (or perhaps it was a review) of the Pioneer I thought I saw Spotify was enabled.
    Perhaps you need to refresh the Pioneer in some way as I imagine Spotify has updated its player.
    Perhaps contact Spotify - they are typically quite responsive.
    E
  4. #124
    think it does airplay so you could perhaps capture via that from an ipad. think a chromecast would be best bang for buck. no it doesnt do spotify ive checked so you will need to work around it.
    Is there a firmware update?
  6. #126
    I'm Edward.
    Another thing you could check is to to see if Airplay is possible on the N50 and use Spotify on your phone and bridge to the Pioneer via Airplay. That would be a cost free option. Or as Grant says go the Chromecast route. Many other routes as well.
    [edit]
    Oh I see that Grant has also mentioned the Airplay method as I was typing.
  7. #127
    I don't have any apple devices, I think Airplay is for apple devices only. I am trying to check for firmware updates, as I think the later models of the n-50k are Spotify compatible.
  8. #128
    What does a chromecast do? Think I'll just put a bloody record on.
  9. #129
    https://store.google.com/gb/product/chromecast_audio. this will work. it can output digital on toslink mini or analogue using its built in dac on a 3.5mm plug. then into your amp. sound quality is good with spotify. will work with most smartphones and tablets and pc's.
    as i say, it should have airplay so if you have apple products then you could try that before spending cash. ive only used it with films to my apple tv box but it will work.
    I'm gone.
    I know what you mean.
    I bypass all the technobabble and fancy widgets and just take a USB cable from my laptop to my DAC. Signed up to Spotify after trying a few music streaming sites.
    Couldn't be happier - I stream 99.9% of my music now. Sorted.
